[Z06] Demon key out - what not to do
Old Apr 8, 2004 | 10:31 PM
jgmachine's Avatar
jgmachine
Default Demon key out - what not to do
Ok, I installed my hurst shifter a few weeks back and put it back in with the stock ****. It rattled, so I bought the MGW **** and also installed the PVC mod too. Rattle is now gone. The problem is that when I tried the second time, I snapped of the top of the demon key. I could not grip it with vice grips.
Here are some pictures of the mess. I had to drill to get out the key. As you can see I drilled then screwed a screw into the hole. I used the vice grips to"hit" it up. Key came right out.Actually only took 5 minutes to do.
Look how much lower than the stock know it is.
[Modified by jgmachine, 9:16 AM 4/10/2004]
Old Apr 8, 2004 | 10:42 PM
Z_OH_6's Avatar
Z_OH_6
Default Re: Demon key out - what not to do (jgmachine)
Guess it's aptly named huh? :lol:
I have the stock shifter in place but it drove me crazy to think that the **** was slanted to the left. I believe that was actually an incorrect perception but in the driver's seat it appeared to be canted. I took out the key and screwed it down one turn to where it 'felt' correct and it fits very snugly, doesn't move and appears perfectly straight. :steering:
Old Apr 9, 2004 | 10:01 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Try hpphoto.com
Old Apr 10, 2004 | 09:08 AM
AFVETTE's Avatar
AFVETTE
Try http://www.photobucket.com free and so far unlimited bandwidth.
The Hurst and MGW are a perfect match. I love the look and feel of mine.
Tom
Old Apr 10, 2004 | 09:16 AM
jgmachine's Avatar
jgmachine
Default Re: Demon key out - what not to do (AFVETTE)
Ok - figured out how to post... Look at how much lower the shift **** is...
[Modified by jgmachine, 9:30 AM 4/10/2004]
Old Apr 13, 2004 | 09:54 PM
stingray454's Avatar
stingray454
I've seen that Demon Key movie before :lol: Those pictures look EXACTLY like what I had to go through (I may have had a bit more metal shavings laying around from the drilling). I still have nightmares from it over a year later. :leaving:
Old Apr 14, 2004 | 12:38 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Were you talking about a C6 around your car? It may have been pissed at you. :jester
Old Apr 14, 2004 | 11:25 AM
J-Rod's Avatar
J-Rod
Default Re: Demon key out - what not to do (lager99)
I'm amazed that you got a sheetrock screw to go into that thing and not snap off.
Old Apr 14, 2004 | 07:19 PM
jgmachine's Avatar
jgmachine
Default Re: Demon key out - what not to do (J-Rod)
The key, or mine was extremely soft. I could have threaded it down more if I wanted to...
Old Apr 15, 2004 | 12:14 PM
dfwroadkill's Avatar
dfwroadkill
St. Jude Donor '07-'09
J-Rod:
Agreed.
:D
To Demon key out - what not to do
