Does anyone have a pic of the CCW street classic wheel in the black anodized finish on an electron blue Z06?? Trying to decide whether to go black anodized or polished finish.
No pictures, but you may want to consider powder coated instead of anodized. The anodized finish will fade/gray after time. Make sure you see a set that's a year or two old before making your decision.
The only thing that I would add is tha up close and personal the black centered CCws look at-least 1" smaller in daimeter than the full polished. When you break up the colors like that (center and lip) the wheel appears smaller than it is, especially in the case of the multi-spoke wheels.
Don't forget to ask John about the options for the bolts. I have the standard, brass colored bolts. You can go with the lightweight titanium option (~1 lbs savings per wheel) which also give a slightly different flare to the wheel.
