i need to know what it would cost to buy an engine and have it installed on a car that i may possibly buy. if anyone has any ideas let me know. thanks :cool:
6900 for a fully dressed LS6 engine(comes with everything down to the manifold)
5200 for a long block if you will be reusing the FI, intake, injectors ect from the old engine.
1200 for a basic install, more if other parts are needed.
the above is true if the same engine is being replaced as came in the car.
more $ if upgrading as in my case where i put a 03 crate LS6 into a 99 :shocked:
I have a brand new 405hp LS6, complete T/body to Flywheel, including
exhaust manifolds, water pump, and most brackets. $5200 firm. I was
going to install this in a hardtop, but I ended up buying a Z06.
i definately want that if i am able to get this car. send me your email address to dustinhelms16@yahoo.com and i will get with you soon as i find out weather or not i can get that car. thanks
