[Z06] Disappointing dyno today
Old May 4, 2004 | 10:01 PM
SharkbyteLT4's Avatar
SharkbyteLT4
Default Disappointing dyno today
Today, I took my car to get dynoed since i never had it done since installing a DTE 4.10 differential and a borla catback.
Before i did those mods, i made 442rwhp and 403 torque on the dyno at Cartek
I about lost my mind when my best pull today was 421.2 rwhp and 380 torque. I didn't know where my torque was going to be, but i expect my hp numbers were going to be over 430rwhp.
The only logical thing i can think of losing the extra 9-12rwhp is that it was like 30 degrees cooler when it was dynoed at Cartek
Old May 4, 2004 | 10:08 PM
ModRed405's Avatar
ModRed405
Default Re: Disappointing dyno today (Y2K253SS)
That's ghey!
I didn't realize that changing the axle ratio would change the recorded output/power. Then again, I don't know a lot about that kinda stuff. You sure do have a nice car, though! :cheers:
Old May 4, 2004 | 11:07 PM
stingray454's Avatar
stingray454
That could certainly do it! I mean that's only a 3% difference, which a 30 degree increase in air temp could cause. :yesnod:
Old May 4, 2004 | 11:12 PM
Shylor's Avatar
Shylor
I assume you had some mods on the car to make 442rwhp.
Old May 4, 2004 | 11:25 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Disappointing dyno today (Shylor)
4.10 gearing
Old May 5, 2004 | 01:04 AM
Shylor's Avatar
Shylor
Default Re: Disappointing dyno today (Jim Hall)
So you're saying by changing the rear end gearing that upped the rwhp? Correct me if I'm wrong but, I don't think that mod will raise the rwhp higher than the rated 405hp.
Old May 5, 2004 | 02:54 AM
kumar75150's Avatar
kumar75150
huh
Going from 4.10 gears will make you lose hp on the dyno.
Thats why he went from 442 to 421rwhp. However, I dont think it cause a loss of 21hp. Part of the loss might have been the warmer weather.
Old May 5, 2004 | 08:55 AM
W!ngnut's Avatar
W!ngnut
No..it was dyno'd at Cartek when they installed the heads & cam pkg. He has added the 4:10 gears and catback.
I understand losing hp due the gears but didn't think it would be that much.
I also thought the correction factor was supposed to make up for the difference in weather/elevation...etc. on dyno's. Did they use the same exact factors as the dyno at Cartek and is it the same exact type of dyno? :confused:
Old May 5, 2004 | 11:11 AM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Re: Disappointing dyno today (W!ngnut)
I would say the for one you are on a different dyno and you could be lower anyway and for 2 the temp difference will hurt youre HP.
Old May 5, 2004 | 11:13 AM
robz's Avatar
robz
Its the gears. I lost 19 hp with the gear swap and others have lost close to 20 as well. Dont sweat the dyno numbers. Your car will run alot faster now provided you get traction to the tires. Trust me, get some et streets and hit the track.
Old May 5, 2004 | 11:49 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Disappointing dyno today (robz)
:iagree: :iagree: :iagree:
Old May 5, 2004 | 04:33 PM
Shylor's Avatar
Shylor
Default Re: Disappointing dyno today (Ruby6spd)
Oh, I didn't know he had other mods that got him up to 442rwhp before his latest mods. I thought that seemed kinda of funny.
Old May 6, 2004 | 12:51 AM
SharkbyteLT4
Want to thank everybody for the support and good feedback from some of the members. I have been wondering why was going on with the car because it didn't have any Knock retard or anything. It was constantly added timing after 6 grand which is how the tune is setup for.
Air/Fuel ration was a little lean, but within tolerable limits. Most be the damn oxygenated fuel :D
Old May 6, 2004 | 09:11 AM
W!ngnut's Avatar
W!ngnut
Lookin' forward to seeing your awesome Z. :cheers:
Old May 7, 2004 | 10:44 PM
Pumba's Avatar
Pumba
Rob,
Can someone explain to me in technical terms how changing from 3.42 gears to 4.10 gears can cause a loss of horsepower?
:confused:
Old May 7, 2004 | 11:07 PM
robz's Avatar
robz
Default Re: Disappointing dyno today (Pumba)
I don't know all the technical details. There was a thread that covered every possible theory on this about 4 months ago. Try doing a search.
Old May 7, 2004 | 11:13 PM
Pumba's Avatar
Pumba
Rob,
Thanks for the reply.
I have spent the past 7 weeks in a rear axle manufacturing facility, and there is no measurable difference in the friction that it takes to turn a 4.10 gear set versus the 3.31, 3.55, or 3.73 gear sets that his plant makes. So, I am not convinced that friction would be a cause of the horsepower difference.
I suspect that there is a computer logic error in the chassis dynamometer's computer.
:confused: :confused: :confused:
To Disappointing dyno today
Old May 7, 2004 | 11:16 PM
kh24's Avatar
kh24
Rob,
:confused:
Im not totally sure on this but think of it as riding a bike. When your in a lower gear its harder to turn the pedal but it turns more forcefully and with more accleration so thats why it dynos lower...again not totally sure about that.
Old May 8, 2004 | 12:29 AM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
Default Re: Disappointing dyno today (kh24)
Its definatley the gears and the warmer weather doesn't help either...
Pumba...
Ask any tuner that has experience with 4:10s... They are proven to dynbo 10 -20 hp lower then 3:42s... go ahead ask LGM, Lingenfelter, MTI, A&A, ECS, Vette doctors, cartek, MTI, A.R.E... Its no new jersey conspiricy... (I can't spell dont make fun of me)
Old May 8, 2004 | 08:28 AM
Pumba's Avatar
Pumba
Default Re: Disappointing dyno today (NJ99FRC)
Alex,
Thanks for the note.
I am convinced that the Tuners that we all use see a 10 to 20 horsepower loss when a customer changes to a 4.10 final drive ratio on their Mustang or Dynojet chassis dynamometers. Does that mean I really have 420 RWHP in my Z06? Or, does it mean those Vette owners with other gear sets should subtract 20 RWHP from their numbers?
I am concerned because when we measure the frictional losses at the rear axle manufacturing plant where I have been working for the past seven weeks, there is no difference between a 3.31 or 3.55 or 3.73 or a 4.10 gear set.
I have watched as the Tuners I use enter my 4.10 gear ration into the chassis dyno's computer. I suspect that the computer has a logic error, and can't correctly convert the rear wheel horsepower for a 4.10, when compared to a 2.73 or 3.15 or 3.42 gear set.
Thanks for your thoughts. :seeya
[Modified by Pumba, 8:32 AM 5/8/2004]
