[Z06] Predator True results
May 6, 2004 | 07:37 PM
St. Jude Contributor
Today we dynoed my gal. The reults of the Predator are in! Keep in mind it is an '02 with only 7100 miles on it. I will scan and post the actual sheets tomorrow.
Performance Tune:
353.4 HP
348.0 TQ
14.8 A/F
Stock Program:
347.2 HP
344.7 TQ
15.4 A/F
$400.00 plus dollars has gotten me and Fan temp controller and a diagnostic tool. :sad:
They may post more but don't be fooled.
I hope this does not get locked.
May 6, 2004 | 07:56 PM
Re: Predator True results (dubya)
I also am waiting for Diablo to respond.
May 6, 2004 | 08:36 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Not fantastic eh? :nonod: What do they claim?
May 6, 2004 | 09:21 PM
The stock tune from GM is actually pretty good. Not much room for improvement. How does an LS1 edit tune stack up?
May 6, 2004 | 10:10 PM
St. Jude Donor '06
Re: Predator True results (Nat04Z06)
Edit's are good for 10-20 depending on the car.
May 6, 2004 | 10:29 PM
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Quote:
Performance Tune:
353.4 HP
348.0 TQ
14.8 A/F
Stock Program:
347.2 HP
344.7 TQ
15.4 A/F
I would have been surprised to see a bigger gain. FWIW, your stock pull was a little low on HP and your after pull is about what a stock Z06 does.
What's with those A/F ratios?
May 6, 2004 | 10:31 PM
Re: Predator True results (lager99)
You're comparing custom LS1 edits with a canned "performance" tune. Get a custom Diablo tune on the Predator, then make a fair comparison.
May 6, 2004 | 10:37 PM
St. Jude Donor '06
Re: Predator True results (slythetove)
I know...that's what Nat asked. "How does an LS1 edit tune stack up?"
[Modified by lager99, 8:38 PM 5/6/2004]
May 6, 2004 | 11:46 PM
Do they want more money than the intial cost of the Predator for a custom tune? :confused:
May 7, 2004 | 07:36 AM
Re: Predator True results (rbartick)
The performance tune is actually better for the Air to Fuel ratios as soo I was told.
May 7, 2004 | 10:02 AM
The A/F ratios you listed above make no sense. Your car cannot possibly be running those ratios @ WOT or it would be much too lean.
In stock form the car was probably running somewhere in the 11.5-12.5 range around the TQ peak, slightly leaner before & after the TQ peak.
May 7, 2004 | 12:11 PM
Here are the Dyno Results.
1st is a comparison
2nd is the Performance Tune
3rd is the Stock Tune
http://www.techsourceall.com/images/Dyno-combined.doc
[Modified by dubya, 11:13 AM 5/7/2004]
May 7, 2004 | 01:05 PM
St. Jude Donor '06
I only see the comparison...not an impressive change is it. :sad:
