Please settle an arguement at work.ty
Old May 26, 2004 | 11:50 AM
misteroman's Avatar
misteroman
St. Jude Donor '17
Default Please settle an arguement at work.ty
I have an 04 Coll Vert auto 3:15 Z-51.Only mods are Borla stingers and a Granetelli Air intake system w/ the bigger piece that goes over the Rad.I strongly believe that it will run in the 12.9's up here in cold NY.People at work say it won't break into the 12's.Whos's right and what is an average time that should be expected.
Derek
Old May 26, 2004 | 12:22 PM
HalfMoon's Avatar
HalfMoon
Default Re: Please settle an arguement at work.ty (misteroman$$$)
Only one way to find out what your car, at your track, with your driving will do. Alot of variables there to work out.
I've never been in an automatic C5, so I can't say, although the thread about a stock auto not being able to spin the tires from a stop made me scratch my head.
Old May 26, 2004 | 12:41 PM
Midwayman's Avatar
Midwayman
Default Re: Please settle an arguement at work.ty (Tony_C5_04)
I would say no.... unless you got one of the strong cars from the factory. Itll probably be real close though.
Old May 26, 2004 | 01:10 PM
msghuff's Avatar
msghuff
Default Re: Please settle an arguement at work.ty (Midwayman)
My old stock 97 auto 3.15 with a k&n ran 12.97-12.95@109 every single time over 10 runs at two diff tracks........maybe I got one of the "stong ones"?
Old May 26, 2004 | 02:03 PM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Please settle an arguement at work.ty (msghuff)
Close...very close...
Depends on driver and reaction time, I'd say...
Old May 26, 2004 | 05:23 PM
MaxPower's Avatar
MaxPower
Default Re: Please settle an arguement at work.ty (SleepieAce)
Probably won't depend on reaction time. :p:
In good air and a well prepped track it is definetly possible. Only one way to find out for sure!
Old May 26, 2004 | 07:26 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
R/T has nothing to do w/ E/T... Maybe you meant 60' time???
Shiftpoints would also affect it, as well as weather & track (prep).
Old May 26, 2004 | 09:54 PM
RobWilson's Avatar
RobWilson
Also depends on the track elevation. That can make a big difference. If you don't get into the high 12s, you will definitely be in the low low 13s.
Old May 27, 2004 | 12:07 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Do you have any baseline runs?
I think it will make it.
Go for a road trip and come down to the Corvette Challenge at E-town, NJ this weekend.
Or you can race it in Buffalo on Jun 4th http://forums.corvetteforum.com/zerothread?id=818031
Old May 27, 2004 | 02:18 AM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Please settle an arguement at work.ty (REDGAR)
I squeaked a 12.99 @ 108 out of my '01 when she was stock with 2.73 gears. The key will be your 60', I got a 1.94 on runflats for my 12.99 run. With 3.15s and your other bolt-ons you should be able to pull it off.
Old May 27, 2004 | 09:32 AM
Demented's Avatar
Demented
Default Re: Please settle an arguement at work.ty (NJVetteGuy)
13.08 stock 01 w/ 2.73's and bald run flats...... there's a 2.73 '03 auto on the board that pulled a 12.87 stock so anything is possible.
Old May 27, 2004 | 11:18 AM
BADBLACK99's Avatar
BADBLACK99
Default Re: Please settle an arguement at work.ty (Demented)
Do a burn out in some pine resin and stage as shallow as possible. I think thats all you can do to help your situation. Should be darn close being as you are running on those magical east coast tracks.
Old May 27, 2004 | 02:29 PM
mdhmi's Avatar
mdhmi
With hot tires, cool air, and a strong launch you might be able to pull off a 12.99.
Mark
Old May 27, 2004 | 03:36 PM
Midwayman's Avatar
Midwayman
Default Re: Please settle an arguement at work.ty (mdhmi)
Maybe they make the tracks downhill on the east coast?
Old May 28, 2004 | 12:39 AM
NJVetteGuy's Avatar
NJVetteGuy
If you've seen the track the tuner shootout was run at, you'd notice it was actually kind of uphill I ran 11.87 down there with a positive DA (1200' I believe), not sure of the track elevation. My sig pic is from that event, it was Jackson Dragway in SC.
Old May 28, 2004 | 09:29 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Default Re: Please settle an arguement at work.ty (BADBLACK99)
Isn't Route 66 where NHRA just set all those records?
Old May 28, 2004 | 02:55 PM
LSK's Avatar
LSK
Yes RT 66 near Chicago is where they just set some NHRA records.
As far as hitting 12s. make sure you dont have a full tank of gas, put your shifter in "3" and raise your idle a few rpm when you launch if the track is hooking good. Practice your launch. Also play the weather, go to the track when the barometer is high and humidity and temp is low.
I think its a 50/50 chance you will do it.
[Modified by LSK, 1:56 PM 5/28/2004]
[Modified by LSK, 1:57 PM 5/28/2004]
To Please settle an arguement at work.ty
Old Jun 2, 2004 | 11:25 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Unless you are at a super fast track out East or get perfect weather and track prepped conditions, etc., you will probably come up a lil short and run around a 13.2 or 13.1 in my opinion. Throw on some 3.90 gears and a Yank Prothruster 4000 stall or a hard hitting Yank 3600 SS converter or so and drag radials (BFGS), and watch your 1/4 mile times drop a full second by just doing these two mods and you will then see ALOT OF JAWS DROPPING!!! Then thow in cam and long tubes and you have yourself a consistent reliable mid to high 11 sec. something daily driver street/strip C5!!!!
[Modified by MTI 427 Roadster, 10:27 PM 6/2/2004]
Old Oct 3, 2004 | 02:29 AM
misteroman's Avatar
misteroman
St. Jude Donor '17
See thread below: not even close
http://forums.corvetteforum.com/show...post1548424787
MTI are 11's really that easy?
D
Old Oct 3, 2004 | 03:01 AM
c5inphila's Avatar
c5inphila
Come to atco, only mods on my 2000 vert were vortex, catback and powerloader on stock runflats the car ran 12.6 to 12.8 in cool weather.
