[Z06] Thermostat
Old May 27, 2004 | 08:58 PM
fastgn's Avatar
fastgn
Cruising
Default Thermostat
Does anyone outhere knows what type of thermostat does the 2003 Z06 has, I had the LS Edit program done in San Atonio, Texas. the Halltech trap system and the entire Magnaflow system. It was recomended that I change the stat because he had programed the fans to come on a bit earlier. I don't know what type of thermostat is the best for the Z06 and I imagine or assume that it has to be a 160 degrees. It dynoed at 388.5 RWHP has not been tested yet at the track too many toys not enough time to use them all.
1969 Plymouth Road Runner 510 CU 10:80's
1970 Plymouth GTX 440 Six Pack
1986 Buick Grand National
1998 Yamaha V-MAX
Old May 27, 2004 | 09:44 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Default Re: Thermostat (fastgn)
Don't know.
Old May 27, 2004 | 11:05 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default Re: Thermostat (pk2401)
Hey PK2401.....Someone has too much time on their hands!
fastgn....Why didn't the people who did all that work on your car answer/take care of the thermostat question??
Old May 28, 2004 | 12:32 AM
fastgn's Avatar
fastgn
Cruising
Dr. Run
San ANtonio, Texas is about 160 miles from Laredo and I do not get outhere that often cuz I work 6 days a week. I should have asked him if he knew how hot of a thermostat the Z had and since I did not so that is why I am asking you smart longtime vette magicians, if you know but I guess you dont. The shop owner stated that I should install a 160 degrees stat as soon as I could and it will be in the Z sometime this weekend if I can get a decent one.
THANKS
fastgn's Avatar
fastgn
Cruising
Dr. Ron
THANKS
Old May 28, 2004 | 12:37 AM
fastgn's Avatar
fastgn
Cruising
Dr. Ron
Sorry for the second reply there I didn't meant to repeat it, just "IGNORE IT"
Old Jun 4, 2004 | 08:00 PM
BHP's Avatar
BHP
195* is stock. Consider a Hypertech 180* available from TByrne Motorsports.
Old Jun 10, 2004 | 07:41 PM
BobA's Avatar
BobA
Default Re: Thermostat (BHP)
I went for the 160. The car seems to run at about 170 to 185 with the 160 so I set my fans to keep the engine heat right there.
BobA
Old Jun 10, 2004 | 10:47 PM
Dr.Ron's Avatar
Dr.Ron
I have a 180* stat which isn't really working properly as compared to others w/ the same temp stat. I had my fans lowered w/ LS1 edit. Many here would argue that 160* is too cold. Many will say 160* is fine. I noticed more people here say it's too low a temp stat. My car seems to run better at warmer temps, so I'm not changing anything. I ran my best times as the car heated up. These cars seem to like heat.
By my too much time on your hands comment I was addressing your picture made out of the icons
[Modified by Dr.Ron, 10:48 PM 6/10/2004]
Old Jun 11, 2004 | 08:51 AM
Ranger's Avatar
Ranger
Default Re: Thermostat (Dr.Ron)
...My car seems to run better at warmer temps....I ran my best times as the car heated up. These cars seem to like heat.
I have about 300 passes in my Z06s.
My car DEFINITELY makes the best ETs and power when the water temp is at 190-195.
If I begin the pass at 180-185 I LOSE .1-.15. Ditto for temps above 200.
So my stock-PCM LS6 has a narrow range of water temps in which it makes best power.
Ranger
[Modified by Ranger, 10:42 AM 6/11/2004]
Old Jun 11, 2004 | 10:39 AM
fastgn's Avatar
fastgn
Cruising
Thank-You guys (Ranger, BHP,BOBA and Dr. Ron) yesterday I ordered a 160* thermostat from Hypertech and it should be here in Laredo sometime in the next week. The reason that I want to change it is because here in Laredo, Texas summer time temps are easily way over 100* for most of the summer and if you're stuck in traffic or in one of the international bridges FORGET IT. I hope that this will aleviate some of the heathing problems.
1969 Plymouth Roadrunner 510 CU
1986 Buick GRand National
1998 Yamaha V-MAX
Old Jun 11, 2004 | 08:29 PM
Dr.Ron's Avatar
Dr.Ron
Default Re: Thermostat (Ranger)
Ranger, I THINk you were agreeing with me. However, let me clarify my post just in case. When I say my car likes warmer temps, I was referring to the temp it achieves after it's warmed up. That temp is in the 192-197* range,similar to as you posted.
[Modified by Dr.Ron, 8:30 PM 6/11/2004]
Old Jun 12, 2004 | 03:38 PM
Ranger's Avatar
Ranger
Yes, Dr. Ron, I was agreeing with your post and providing some amplification. Sorry I wasn't more clear.
I guest-drove a 2001 Z06 at the drags today. Car had an intake, LT headers and 3.90 gears. BUT he had the water temp regulated to max-out at 185, which is ten degrees colder than mine runs. I couldn't get the car to trap above 113 in three passes. Should have been trapping 115. I attribute the MPH-loss to reduced power from the colder engine temp.
Ranger
To Thermostat
