c6 intake
Old Jun 5, 2004 | 06:29 PM
1320dance's Avatar
1320dance
Default c6 intake
will the c6 intake fit our c5 thanks
Old Jun 5, 2004 | 07:07 PM
Demented's Avatar
Demented
Default Re: c6 intake (1320dance)
Doubt it..but a better question is...will the 90 mm C6 throttle body fit the c5:P
Old Jun 5, 2004 | 07:40 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
I heard the intake even has a diff shape port so I wonder what the heads look like--
Old Jun 5, 2004 | 08:48 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I think the bigger question is... will we want a C6 intake on our C5's??
VR
Old Jun 5, 2004 | 09:34 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: c6 intake (vetterdstr)
VR
If it flows better than the one I have? Then yes, I want it on my C5.
Old Jun 6, 2004 | 02:35 AM
vetterdstr's Avatar
vetterdstr
Default Re: c6 intake (Z06ufgrad2002)
Its your choice to install that stuff if you want to. Maybe installing the entire C6 engine would be better?? then again putting parts on your car like that would effect smog.
VR
Old Jun 6, 2004 | 09:30 AM
NEPTUNEBILL
Whatever the intake does I know the FAST 90mm setup on other than stock cars is getting as much as 25rwhp--as impressive as your car is for stock heads the FAST and heads would put you in the 475rwhp range with torque in the 430 range--if I had had the cam, heads and intake options 4 years ago I have now I would be running a setup very similar to yours with the addition of the heads and FAST and have the perfect balanced street car even though there is no street tire out there that will hold 475rwhp very well at all--
Old Jun 6, 2004 | 03:25 PM
Automag928's Avatar
Automag928
To my understanding the LS2 engine uses LS6 heads, the main difference on the intake will be the 4 bolts for the 90mm TB.
Old Jun 6, 2004 | 03:30 PM
HalfMoon's Avatar
HalfMoon
Default Re: c6 intake (Automag928)
All the reports from the people that have seen and driven a C6 is that they use heads with the same casting numbers as LS6 heads.
Old Jun 6, 2004 | 04:59 PM
NEPTUNEBILL
Default Re: c6 intake (Tony_C5_04)
That's true J-rod took some pics under the hood at an auto show and had a close up of the casting number---
Old Jun 8, 2004 | 09:39 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Old Jun 8, 2004 | 10:16 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I have a TPIS Throttle Body that has been ported and oval, and the intake is oval and ported as well by TPIS. Its an awsome set up.
Old Jun 9, 2004 | 01:21 AM
Darkness's Avatar
Darkness
Default Re: c6 intake (mikes99corvette)
This will be a popular mod, LS2 intake and TB
To c6 intake
