[Z06] Water Wetter
Old Jun 16, 2004 | 02:09 PM
Gasser82's Avatar
Gasser82
Default Water Wetter
Has anybody ever used this product, and how well did it work. Any feedback or thoughts would be useful. thanks
Old Jun 16, 2004 | 02:28 PM
nuke61's Avatar
nuke61
Default Re: Water Wetter (Gasser82)
It works great. I drained the radiator, figured out the *minium* amount of Antifreezed needed, used distilled water, and WaterWetter. Dropped average temperature by about 10 degrees.
Old Jun 16, 2004 | 03:52 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Read many articles on this item. Pure BS for your stock Corvette.
There is NO water in your Corvettes radiator, so adding this concoction is worthless. However if you run only water or a "minimum" of H2O, then you'll be ok...........
Old Jun 16, 2004 | 04:10 PM
CAPN17's Avatar
CAPN17
Water wetter is a good product that works to reduce overall temp. in the engine by improving the waters ability to transfer heat. Redline makes one product, Royal Purple has a similar product that works as well.
Old Jun 16, 2004 | 04:19 PM
C6~Missle's Avatar
C6~Missle
Default Re: Water Wetter (nuke61)
It works best with just water. Your thermostat will regulate water temps. So anything gained is still going to be regulated by the stat.
It's works best in all water systems that run temps greater than thermostat
operation.
mike
Old Jun 16, 2004 | 05:35 PM
User 81424's Avatar
User 81424
Default Re: Water Wetter (C5~Missle)
It works great. I drained the radiator, figured out the *minimum* amount of Antifreezed needed, used distilled water, and WaterWetter. Dropped average temperature by about 10 degrees.
operation.
mike
You do need water in your system for WW to work. WW eliminates water's natural surface tension, this surface tension when combined with a hot spot will maintain a bubble of steam around the hot spot, WW will not allow the bubble to form and your coolant can now get to the hot spot.
Old Jun 16, 2004 | 07:34 PM
Gasser82's Avatar
Gasser82
Default Re: Water Wetter (CPT Z06)
Thanks for the input on water wetter, ideally i,m hoping that the fan won,t come on as much during idle on these hot days in the south.
Old Jun 16, 2004 | 08:55 PM
ZO6Les's Avatar
ZO6Les
I have run a commercial water wetter when I track the car, and as others have said it works best with little or no antifreeze. On the C5 you will do better to get a 178 stat and have the fans come on early. On the other hand the car will run fine right the way it come from the factory, so it all depends on how you plan to use the car.
Les
Old Jun 16, 2004 | 09:11 PM
nuke61's Avatar
nuke61
Default Re: Water Wetter (VNAMVET)
What in the world are you talking about? No water in the radiator? Hello... it's a water and anti-freeze mix. Water has a much greater specific heat capacity than anti-freeze does, so using pure water would increase the ability of the cooling system to keep the motor cool. However, WaterWetter, as said by others, is a mild surfactant and breaks water tension to allow for better heat transfer. If I remember correctly, it also has a lubricant for the water pump and pump seals.
Old Jun 16, 2004 | 11:17 PM
SQEZN BI's Avatar
SQEZN BI
Put it in and didn't see any changes.
Old Jun 17, 2004 | 06:45 PM
VNAMVET's Avatar
VNAMVET
What in the world are you talking about? No water in the radiator? Hello....................... it's a water and anti-freeze mix.
There is NO water in the Dexcool which is provided from GM for the factory....... and you do not have to change it for 150,000 miles/5 years. HOWEVER, if you need to add, use a 50/50 mixture of Dexcool AND water...............
Old Jun 17, 2004 | 08:56 PM
nuke61's Avatar
nuke61
I don't undestand why you believe that, please explain.
Here's the quote and my source for the coolant in the C5 being (as usual) a 50/50 mix of Anti-freeze and water. Actually, it says 55% Dexcool, but that's close enough for our purposes
Quote from Hib Halverson article:
Coolant put in LS1s at Bowling Green is a mix of 45% tap water and 55% ACDelco, "Dex-Cool," a unique ethylene-glycol antifreeze with a non-slicate, anticorrosive chemical package. [end quote]
http://www.idavette.net/hib/C5diy/c5diy1.htm
Maybe, maybe not. Do a Google search on the terms "Dexcool" and "lawsuit" and you'll get lots of hits from people who are NOT happy with Dexcool.
http://snipurl.com/75v9
C5~Missile, it also involves cars where only Dex-Cool was used. Texaco says the problem is that Dex-Cool does NOT get along well with oxygen. Keep your cooling system completely topped off and they say you should have no problems. When they say topped off, they mean fill to the HOT mark when the car is cold. No air = no problems, per Texaco and GM.
I had a 96 Camaro where we used *only* Dex-Cool and in 4 years we had sludge, then I did a search and found out about the Texaco recommendation to keep it completely topped off.
[Modified by nuke61, 4:07 AM 6/18/2004]
Old Jun 17, 2004 | 09:18 PM
C6~Missle's Avatar
C6~Missle
Dexcool is good stuff! It just can't be mixed with conventional coolant. Some have switched over from conventional without flushing their systems. This causes a gel to form and blocks passages.
If you continue to use only dexcool in your corvette, you will have no problems. Had it in my 99 for 5 years and still looked new when I changed it out..
mike
Old Jun 18, 2004 | 09:11 PM
Shylor's Avatar
Shylor
Your are incorrect. Dexcool in your car is a 50/50 mix of water and straight Dexcool fluid. Using straight Dexcool is almost as bad as using straight water.
Old Jun 18, 2004 | 10:49 PM
TheDVS1's Avatar
TheDVS1
Default Re: Water Wetter (Shylor)
No modern automobile engine should run either straight water, or straight anti-freeze. Typically it's an approximate 50/50 mix of both, and you should use distilled water when topping off to prevent mineral deposits forming in the cooling system. Straight water cools the best, but obviously you'll have freezing/corrosion problems with that formula. Straight anti-freeze is not a great transfer medium, and your engine will run warmer than it should.
And no cooling system should have any air pockets in it. Air in the system will create steam pockets that can wreak havoc in a radiator, not to mention the car will run hot. This isn't a problem with any modern cooling system that uses an overflow reservoir. The cooling system will naturally purge air as coolant is pushed in and sucked out of the reservoir. Just keep it at the proper level.
Cheers.
Old Jun 18, 2004 | 11:14 PM
nuke61's Avatar
nuke61
Default Re: Water Wetter (THEDVS1)
Exactly, that's why I drain the coolant, add the minimum amount of anti-freeze (roughly 25% for Southern California) and distilled water mixture, with 1 or 2 bottles of WaterWetter. That's how you'll drop coolant temperature, assuming that it was running higher than thermostat temperature to begin with.
To Water Wetter
