[Z06] Hypertech programer????
Old Jun 19, 2004 | 05:58 PM
turbo altezza's Avatar
turbo altezza
Default Hypertech programer????
i was offerd a great deal on one from a guy i know, can someone tell me about it, so i can figure out if i even have a need for it
Old Jun 20, 2004 | 08:55 PM
GOOSE JR.'s Avatar
GOOSE JR.
Default Re: Hypertech programer???? (turbo altezza)
I'm not able to tell you much about the Hypertech but you might use this for comparison. I've recently had a Vinci Boss cam installed and I bought the Vinci Programmer some of the features are changing the speedometer for gears or different size tires, you can read codes and remove them from the PCM, it has 6 programs for different cam profiles, you can adjust the timing and fuel curve up or down by a maximum of 10%, adjust rpm and it is adjustable for using larger injectors. One feature that I like is the ability to reinstall the stock settings. I noticed a big difference in power after the cam install and a even bigger power and drivability change after the tuner installation. The tuner cost $459 it's the best tool for me. that's my oppinion, hope it helps.
Old Jun 21, 2004 | 07:49 AM
C5 CU's Avatar
C5 CU
it is of little to no value for a ZO6, does not help tune...
Old Jun 21, 2004 | 09:38 AM
dbvettez06's Avatar
dbvettez06
Default Re: Hypertech programer???? (C5 CU)
Save your $$$
Old Jun 21, 2004 | 03:16 PM
bobby777's Avatar
bobby777
Default Re: Hypertech programer???? (dbvettez06)
A Joke!Without a dyno tune dont buy an after market devise.
Old Jun 21, 2004 | 07:48 PM
Painrace's Avatar
Painrace
It will allow you to raise the rev limit to 7,100 by 100RPM's; Set fan temps for lower thermostat; computer upgrade is about 5 HP; you can change tire of gears and adjust both. There are other features I can't remember but a dino tune/good shop would do more.
To Hypertech programer????
