[Z06] Need Help with Z06 Custom Harness Bar install
Designs that use the stock bolt generally have a "loose" fit such that support bars must be connected between the harness bar and the seat rear mounting point point on each side of the bar. (like r-dracing.com)
My design requires the bar end tabs to be tightly bolted into the shoulder location. The space between the bar end tabs and the shoulder mounting point will be taken up by a collar.
I want to enter a track event at Blackhawk farms racetrack this weekend.
I did a bit of searching on the forum but did not find any info.
Any help would be greatly appreciated !!!
