[Z06] Rear wheels different ??
Old Jun 30, 2004 | 08:17 PM
dan-t's Avatar
dan-t
Default Rear wheels different ??
01, just bought couple days ago ..just noticed rears look alittle different. Could this be my problem with what seams like traction control kicking on at 5200 rmps or soo...torque management ?? .. Are 01 different wheels than newer z's? thanks
Old Jun 30, 2004 | 08:39 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Rear wheels different ?? (dan-t)
01 Z06 wheels are unique to that year. They were made through a different process (forged I think, while the newer ones are spun-cast) and the spokes are just a bit edgier than 02+ Z06's.
[Modified by Corvette SSX, 7:39 PM 6/30/2004]
Old Jun 30, 2004 | 09:15 PM
dan-t's Avatar
dan-t
Default Re: Rear wheels different ?? (Corvette SSX)
thanks...one wheel looks shinny, the other don't..one has wider lip. Could this cause my problem???
Old Jul 1, 2004 | 03:22 AM
dan-t's Avatar
dan-t
both back wheels are wider looking than the fronts but one rear different from other.Where is size located on wheels? thanks for any help
Old Jul 1, 2004 | 07:16 AM
grsz06's Avatar
grsz06
The rears look different from each other, or they look different from the fronts?
[Modified by grsz06, 6:16 AM 7/1/2004]
Old Jul 1, 2004 | 10:17 AM
dan-t's Avatar
dan-t
Default Re: Rear wheels different ?? (grsz06)
back 2 diff from front and back 2 diff from each other...sorry for being unclear.
Old Jul 1, 2004 | 11:06 AM
wamara's Avatar
wamara
Cruise-In II Veteran
They're different diameters and different widths - I'm sure this is simply what you are noticing....
Old Jul 1, 2004 | 12:01 PM
pnielsen's Avatar
pnielsen
Default Re: Rear wheels different ?? (wamara)
That does not sound right. The rear left and rear right wheels should be identical...
Old Jul 1, 2004 | 12:39 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Default Re: Rear wheels different ?? (pnielsen)
Sounds like one of the rears is an 01. I think the wheel colors were slightly lighter on the 01's also. If you look on the inside part of the wheel, the 01 has the name of the manufacturer on it.
Old Jul 1, 2004 | 08:11 PM
dan-t's Avatar
dan-t
Default Re: Rear wheels different ?? (Zoomin)
looked at a 02 at lot today..3 of mine looked like those, one rear of mine didn't.I will have to wash car and check inside of wheel.thanks to all.
Old Jul 1, 2004 | 10:47 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I'd go back where you bought it & get straightened out, if not, straighten THEM out!
Congrats & good luck!
Old Jul 1, 2004 | 11:49 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Rear wheels different ?? (Dr.Ron)
The stock wheels from my car ('01) have sharp edges on the spokes and dark gray paint. The '02+ wheels ahve rounded edges and are a lighter gray. The '01's are forged and the '02+'s are spun cast.
Old Jul 2, 2004 | 02:38 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi dan-t -
You say one wheel has a wider lip...that would not be right.
Wheels absolutely need to be matched side to side, as do tires.
As stated by the other posts - the '01s and a few early 02's came originally equipped with forged alloys, all the rest of the Z06 production were equipped with spun-cast wheels made in Italy by Speedline. These later wheels have small pockets cast into the back side of some of the spokes, and also sport the speedline logo.
The 02 wheels have a lighter tone of gun-metal color than the darker 01 wheels, and they are lighter in weight that the earlier wheels.
The sizing is the same throughout the production - with the fronts in 17"x9.5" and the rears in 18"X10.5".
I cannot say how the traction control would be affected by a wider wheel on one side of the rear of the car, if it would be affected at all.
I would expect a tendancy to kick to one side under agressive acceleration with a mis-matched wheel setup on the rear.
Good luck!
best regards -
mqqn
[Modified by mqqn, 1:41 PM 7/2/2004]
Old Jul 2, 2004 | 03:48 PM
dan-t's Avatar
dan-t
Default Re: Rear wheels different ?? (mqqn)
well i looked for markings on wheels but did not see any.they are prolly the same size but are different wheels for sure. cousin said he would have time next week to do more testing at gm shop. He talked to other techs on line they are thinking it is a torque or abuse management issue.He will also messure wheel for me..thanks again for the help everyone....have a safe 4th...oh ya...take yours to red line for me ...
To Rear wheels different ??
