[Z06] Need some help on first mods
[Modified by Black 45, 2:58 AM 7/6/2004]
[Modified by Black 45, 2:59 AM 7/6/2004]
http://www.lgmotorsports.com/
I did the Blackwing air filter & cold air schroud and replaced the belows type coupler between the air bridge and the throttle body. I could "feel" the difference within a mile.
We all are a bit crazy with these cars. The biggest problem is getting the power to the ground in 1st and sometimes 2nd gear.
Check behind your throttle body for oil. If you find some, you may need a new valley cover and seals for the PCV system.
