[Z06] LEAK IN THE CAR
Old Jul 8, 2004 | 01:34 AM
turbo altezza's Avatar
turbo altezza
Default LEAK IN THE CAR
it has rained here and my in the back of my drivers seat its full of water. A buddy of mine said in his firebird it happend in the same place when it rained from the window. Could this be my problem? I have pics i will post tommorw
Old Jul 8, 2004 | 08:55 AM
C6~Missle's Avatar
C6~Missle
There are leaks where the roof meets the windows. Along the channel it can leak onto the headliner... The problem is solved with some sealant.
mike
Old Jul 8, 2004 | 09:25 AM
CAPN17's Avatar
CAPN17
The old way to find a leak is to shut the car up tight with the fan for the HVAC running full blast. I like to use a doctors stethescope to listen along the window and door edges for wind noise. If you are a smoker, you can use a lit cigarette to show where air is being forced out. Mark the areas you find a leak with a piece of masking tape the come back and built up under the weather stripping with some putty caulk, black preffered.
To LEAK IN THE CAR
