Hand Break Ajustment
Old Jul 8, 2004 | 04:14 PM
BADBOYINDC's Avatar
BADBOYINDC
Default Hand Break Ajustment
HOW DO I AJUST THE HAND BREAK CAN SOMEONE HELP ME IS IT HARD WHAT DO I DO I :shocked: HAVE A 2002 C5
Old Jul 8, 2004 | 04:28 PM
WildWolf's Avatar
WildWolf
Pull it up and down 5 times ( I think it is actually 3 but 5 won't hurt). Good luck. If that doesn't fix it, take it to the dealer. :flag
Old Jul 8, 2004 | 04:30 PM
Lex Luthor's Avatar
Lex Luthor
The adjustment for the handbrake is by the rear tires. Its a circular click wheel. I don't remember if you turn it clockwise or counter to tighten. But you will need to remove the rear wheels to access it. Hope this helps.
Old Jul 8, 2004 | 05:42 PM
If pulling up the brake handle a few times does not do it, then you can take the rear wheels off and adjust the star wheel. If you do a search, there have been a number of threads on how to adjust the e-brake. Me, I just take mine to the dealer and let them do it.
Old Jul 8, 2004 | 06:41 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Does the dealer do it under warrantee or is that a wear and tear item?
Old Jul 8, 2004 | 07:14 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
you have to take the wheels, calipers, caliper brackets and disks off to make the adjustment.
Old Jul 8, 2004 | 07:40 PM
LoneStarFRC's Avatar
LoneStarFRC
As far as warranty goes I have heard several people say they were able to get the dealer to do it. Be aware that some dealers are going to try to tell you "it's the parking brake handle assembly, and it has to be replaced". (At this point your meter should be fully pegged). As stated, the fix is removing the rear wheels, caliper and rotor and making the adjustment properly. I did mine quite a while back and it is still holding just fine. HTH
Robert
Old Jul 8, 2004 | 07:58 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Try this link
https://www.corvetteforum.com/techtips/viewsubtopic.php?SubTopicID=158&TopicID= 1
Old Jul 8, 2004 | 08:47 PM
Lex Luthor's Avatar
Lex Luthor
Just the wheels, its placed opposite the the rear calipers.
Old Jul 9, 2004 | 08:53 AM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
And if I remeber correctly you turn counter clock wise...you will see as your turn the wheel it will push the shoes out against the inside of the rotors....... I would started with 10 clicks to get mine tight again.
What part of Md are you in? If you want to take a ride to central Pa I can help you out. It really is easy do not pay the dealer to do this
To Hand Break Ajustment
