tire pressure sensors wont program
Old Jul 8, 2004 | 09:05 PM
natedog4g's Avatar
natedog4g
Default tire pressure sensors wont program
does anyone have any idea why after i put on my new wheels(chrome Z06) i cant get the two rear TPS to program, i put them back to the same pos. they were in before. also how do i upload pics onto this thread i would love to show the car.
Old Jul 8, 2004 | 09:11 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you used the same sensors, and put them back into the same locations on the car, you shouldn't need to reprogram them.
It sounds like you were able to get the front sensors to respond? If so, I don't know what to suggest other than the possibility the rears were damaged during the tire mounting.
To post a picture, you need to have your pictures hosted on the web already, and put the link to the pic between the [ img] and [ /img] tags to display it in a thread or your signature.
Old Jul 8, 2004 | 09:14 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Reprogramming is often needed after tire removal.
With your new wheels, you may need a stronger magnet that you previously used.
You might try that, and make sure you are using the proper sequence.
Hope that helps.
Old Jul 8, 2004 | 09:18 PM
natedog4g's Avatar
natedog4g
all but one of them(the rear left) was working when i put them back on, so i figured i would just reset them all, when i get to the right rear it will not program, but it worked for a while after i put the tires back on so i figured it didnt get damaged during the tire change. and about the pic. upload is it possible to pull it out of the (my pics) on my comp.
Old Jul 8, 2004 | 09:24 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Nope, it has to be hosted online somewhere. I think http://photobucket.com is becoming a popular choise for free pic hosting, you may want to look into that...upload your pics to them, then get the full url to the pic to display it here.
Old Jul 8, 2004 | 09:46 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Hope that helps.
I bought a strong magnet and then wave it around in circles in the area of the sensors... ...I waxed on and waxed off until it registered...
Old Jul 8, 2004 | 09:50 PM
natedog4g's Avatar
natedog4g
the magnet i used worked on the fronts so it should be good enough, shouldnt it? i got a pic uploaded in a new thread, check it out.
Old Jul 8, 2004 | 09:51 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
First, how old are your sensors? Their batteries do get weaker over time - maybe the new wheels are just enough to block a marginal signal. Also, did you get new tires at the same time? I have heard that the structure of some tires can also weaken the signal.
Old Jul 8, 2004 | 09:56 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
AHHHHH SOOOooooooo Grasshopper. Vely wise of you. I get Radio Shrack woofer, rip it apart, and can now train my whreels without leaving my den. I can awso pull my pickem up truck with magnet. Vely, vely strong.
Old Jul 8, 2004 | 10:01 PM
natedog4g's Avatar
natedog4g
i assume they are the originals, but they were working fine. i put on new GY EMT's at the same time. i do like the subwoofer magnet idea, i have a nice solobaric 10 that may do the trick if that is all it needs.
Old Jul 8, 2004 | 10:50 PM
If they are not responding, try reprogramming them. If that doesn't work, then they may have been damaged when the tires were put on.
Old Jul 8, 2004 | 10:55 PM
sts57c5's Avatar
sts57c5
hey i had the same problem when i got my mich run flats put on my sensor on rear left is bad and dealer wanted to charge me 350 to replace sensor is still out no way i will pay that amount to get it fixed.
To tire pressure sensors wont program
