left rear wheel
Old Jul 9, 2004 | 08:18 AM
msnbound's Avatar
msnbound
Default left rear wheel
I lowered my car approx. 400 miles ago, and someone noticed that my left wheel, while driving, is wobbling and not straight??....any clues???.....alignment problem, or rim problem???....thanks for much help!!!
Old Jul 9, 2004 | 09:09 AM
CE2004's Avatar
CE2004
Can you feel that while driving? If its bad enough to notice, I would think that inside its pretty significant too???
Old Jul 9, 2004 | 10:20 AM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
A wobble noticable from the wheel is a wheel problem.
Old Jul 9, 2004 | 01:12 PM
JeremyMSG's Avatar
JeremyMSG
Go outside as soon as you can and check the torque on your wheel lugnuts. If they are all good and tight to 100 lb/ft then take the car to a local shop and get it up on a rack. Put the car in N and turn the rear wheel by hand to check for a bad tire or a bent wheel. Good Luck :flag
Old Jul 9, 2004 | 01:13 PM
Check to make sure your lugs are tight - if so, get a good tire shop to check the wheel/tire for damage.
To left rear wheel
