OK, I've searched the FAQ's and other locations, all with no luck. Can you tell me how do do a quote from another message. I appreciate your help.
If you are replying to a message, just click the quote button under that post.
If you want to quote text from somewhere else, just put the text between the
[ quote] and [ /quote] tags.(minus the spaces I purposely put in so you can see the code without it actually quoting it).
If you want to quote text from somewhere else, just put the text between the [ quote] and [ /quote] tags.(minus the spaces I purposely put in so you can see the code without actually quoting it?
