column lock recall
Sounds like a scam to me! When she called up the service
record from the dealer she had all the info at hand. Why do
they need all my originals? So I won't have any records if
I eventually do get the recall? I relayed this to the NHTSA
with my opinion that Chevy was ignoring this safety recall.
Can you say disgusted?
in this case buy a CLB and move on...
WRONG!The lock DOES NOT UNLOCK, which is the problem. It binds, which causes the BCM to shut fuel. The latest recall is to prevent the BCM from failing to shut fuel in some cases where the steering is locked but the BCM gets confused due to low voltage conditions and thinks the lock is actually unlocked.
As previously said, continuing to wait for GM do fix this is asking for trouble. The CLB is the only real solution. I'm amazed that after 5+ years of this problem there are so many posts and confusion on the issue.
Your right the lock doesn't unlock!! What was I thinking!!! So the pin that does the locking is either jambing when engaged or is sticking upon retraction. So is the solenoid crap or is the pin trying to go into a hole that is to small and over time is galling up creating the bind.
Since GM cant figure out how to fix the problem with the column lock itself due to to many variables beyond their control that could cause failure,they eliminated it from the 2001 A4 and eliminate it on earlier A4 models with the recall bypass
Since they cant eliminate the column lock from the M6,it is understandable that the only correction for the M6 is to install the CLB
