born on date
Old Jul 11, 2004 | 11:29 AM
HERK's Avatar
HERK
Default born on date
1G1YY32G635123373 please thank you
Old Jul 11, 2004 | 03:00 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Here's your info Herk
VIN : 1G1YY32G635123373
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2003 CORVETTE CONVERTIBLE Warranty Start Date : 03/05/2003
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : BRUCE GLUECK CHEVROLET, INC.
PO BOX 431
JASPER , FL 32052-0431
(386) 792-1111
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/27/2004 010873 # F2005 - COVER AND/OR GASKET, DIFFERENTIAL - REAR DIFFERENTIAL - LE 4561 miles
03/08/2003 058918 # E0420 - WHEEL - ONE - R&R OR REPLACE 261 miles
02/25/2003 A23373 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY32G635123373
VEHICLE BUILD
Gross Vehicle Weight Rating : 1672 kg (3687 lb) Order Number : FXNMKC
Build Date : 02/25/2003 Build Plant : 135Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS: INSIDE REARVIEW&LEFT OUTSIDE REARVIEW
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS
FFS - FUEL SYSTEM GMX215-GMX245 PULL-AHEAD F55 - MAGNETIC SELECTIVE RIDE CONTROL
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3:15 PERFORMANCE RATIO
IL4 - TRIM INTERIOR DESIGN JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QD4 - STYLED ALUMINUM WHEEL
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z25 - 50TH ANNIVERSARY PACKAGE 1SC - 50TH ANNIVERSARY EDITION * MEMORY PACKAGE * ELECTROCHROMIC MIRRORS:INSIDE REARVIEW&LEFT OUTSIDE REARVIEW * MAGNETIC SELECTIVE RIDE CONTROL * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN * TWILIGHT SENTINEL * HEAD UP DISPLAY * 50TH ANNIVERSARY PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS 15I - SHALE INTERIOR TRIM
154 - 50TH ANNIVERSARY SHALE 54T - 50TH ANNIVERSARY SHALE
94U - 50TH ANNIVERSARY RED
Old Jul 11, 2004 | 03:36 PM
HERK's Avatar
HERK
thanks sponge : :
Old Jul 11, 2004 | 08:30 PM
CCRider's Avatar
CCRider
Default Born on Date
Can I get the Born On Info. on Mine? 1G1YY32G6X5122486.
Old Jul 12, 2004 | 02:04 PM
Sponge Vette
VEHICLE INFORMATION
Merchandising Model : 1YY67 Warranty Start Date : 02/21/2000
Delivering Dealer : GEORGE MOORE CHEVROLET, INC.
PO BOX 50159
JACKSONVILLE BEACH , FL 32240-0159
(904) 249-8282
CLAIM HISTORY
07/10/2003 193462 # J4206 - WIRES AND/OR BOOTS, SPARK PLUG - ONE - REPLACE 41785 miles
07/10/2003 193462 0 M0017 - LUBE, OIL AND FILTER 41785 miles
06/09/2003 192161 # E7200 - CYLINDER, IGNITION LOCK - R&R OR REPLACE 40983 miles
05/27/2003 191699 # N4800 - MODULE, COMPUTER (CONTROL) BODY - REPLACE 40515 miles
05/27/2003 191699 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 40515 miles
05/27/2003 191699 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 40515 miles
04/18/2003 190356 0 M0017 - LUBE, OIL AND FILTER 39204 miles
01/03/2003 186888 0 M0017 - LUBE, OIL AND FILTER 35427 miles
10/18/2002 184381 0 M0017 - LUBE, OIL AND FILTER 32535 miles
07/29/2002 181574 # J9993 - CUSTOMER CONCERN NOT DUPLICATED 29972 miles
06/07/2002 179866 0 M0017 - LUBE, OIL AND FILTER 28235 miles
06/07/2002 179866 # C2368 - GRILLE, DEFROSTER OUTLET (ONE OR BOTH) - REPLACE 28235 miles
03/01/2002 176708 0 M0017 - LUBE, OIL AND FILTER 25656 miles
11/02/2001 173013 0 M0017 - LUBE, OIL AND FILTER 21395 miles
08/13/2001 170234 # N2871 - RELAY - STEERING/SUSPENSION/RIDE CONTROL - REPLACE 18478 miles
08/13/2001 170234 # Z7902 - 2-DAY COURTESY TRANSPORTATION 18478 miles
08/06/2001 169999 # T2020 - TOWING 18368 miles
08/06/2001 169999 # V0743 - ECL RELAY HARNESS REPLACE 18368 miles
08/06/2001 169999 0 M0017 - LUBE, OIL AND FILTER 18368 miles
06/05/2001 167872 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 16151 miles
06/05/2001 167872 0 M0017 - LUBE, OIL AND FILTER 16151 miles
06/05/2001 167872 # J4100 - GENERATOR ASSEMBLY - REPLACE 16151 miles
06/05/2001 167872 # Z7901 - 1-DAY COURTESY TRANSPORTATION 16151 miles
01/02/2001 162862 # N2821 - RELAY - FUEL SYSTEM - REPLACE 11268 miles
01/02/2001 162862 # Z7902 - 2-DAY COURTESY TRANSPORTATION 11268 miles
12/21/2000 162543 # J6355 - POWERTRAIN CONTROLLER - ON CAR - REPROGRAM 11148 miles
12/21/2000 162543 # C0101 - GLASS, FRONT DOOR - LEFT - ALIGN 11148 miles
12/21/2000 162543 # Z7905 - 5-DAY COURTESY TRANSPORTATION 11148 miles
12/15/2000 162353 0 M0017 - LUBE, OIL AND FILTER 10923 miles
12/15/2000 162353 # B3980 - FOLDING TOP - ALIGN OR ADJUST 10923 miles
12/15/2000 162353 # C1280 - WEATHERSTRIP - REAR COMPARTMENT OPENING - ALIGN OR REPLACE 10923 miles
12/15/2000 162353 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 10923 miles
09/11/2000 159053 0 M0017 - LUBE, OIL AND FILTER 7625 miles
09/11/2000 159053 # E7200 - CYLINDER, IGNITION LOCK - R&R OR REPLACE 7625 miles
09/11/2000 159053 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 7625 miles
04/18/2000 153986 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 2395 miles
04/18/2000 153986 0 M0017 - LUBE, OIL AND FILTER 2395 miles
04/18/2000 846262 # T2020 - TOWING 6178 miles
01/28/2000 151485 # J4226 - PLUGS, SPARK - ONE - REPLACE 42 miles
01/17/2000 151103 # B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 28 miles
01/17/2000 151103 # J4217 - SPARK PLUG - ONE - DIAGNOSTICS WITHOUT REPLACEMENT 28 miles
01/17/2000 151103 # B7241 - BEZEL - HEADLAMP - LEFT - REPLACE 28 miles
01/03/2000 150682 # J0920 - OIL LEVEL INDICATOR - REPLACE 27 miles
12/30/1999 150573 # J4217 - SPARK PLUG - ONE - DIAGNOSTICS WITHOUT REPLACEMENT 27 miles
11/05/1999 148953 # C4200 - CARPET, FLOOR - RIGHT - R&R OR REPLACE 8 miles
03/08/1999 A22486 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY32G6X5122486
VEHICLE BUILD
Gross Vehicle Weight Rating : 1690 kg (3726 lb) Order Number : BHPWZH
Build Date : 03/08/1999 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CJ2
C05 DL5
DL8 FE1
FE9 G90
G92 IL3
JL4 JL9
K63 LS1
MX0 M30
NF2 NK4
N37 QD4
T82 T96
UN0 UV6
UZ6 U1S
U52 U75
VM3 V49
V73 XGG
YGH 1AY
1SA 19I
193 41T
70U
a little bit of a wrap sheet on this one.
Here is a link to help you with the codes.
Options codes
Old Aug 22, 2004 | 02:45 PM
2Grumpy's Avatar
2Grumpy
Default Born Date
Hi,
Could you get me the born date info on 1G1YY12S945120820?
thanks,
Old Aug 22, 2004 | 02:59 PM
Sponge Vette
Originally Posted by 2Grumpy
Hi,
thanks,
Recall Notice:
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04043 LOWER CONTROL ARM WASHER 08/18/2004 Open
VIN 1G1YY12S945120820
VEHICLE BUILD
Merchandising Model : 1YY37 -2004 CORVETTE Z06
Gross Vehicle Weight Rating : 1609 kg (3548 lb) Order Number : GJHXZD
Build Date : 02/02/2004 Build Plant : 145Y
OPTION CODES
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
E2C - ORDER TO DELIVERY - EXPEDITE FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IP2 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
P36 - WHEEL 17X9.5 FRT & 18X10.5 RR, ALUM POLISHED R8C - CORVETTE MUSEUM DELIVERY
R9M - TSE ORDER TYPE - OLYMPIC CARS R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS UN0 - AM/FM STEREO W/CD PLAYER
U73 - FIXED MAST ANTENNA VDC - VEHICLE INFORMATION CD
XFW - FRONT TIRE-P265/40R17 YFU - REAR TIRE-P295/35R18
Z16 - COMMEMORATIVE EDITION 1SB - COMMEMORATIVE EDITION * MEMORY PACKAGE * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * COMMEMORATIVE EDITION
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
19U - LEMANS BLUE 192 - BLACK COMMEMORATIVE
Old Aug 22, 2004 | 03:38 PM
SilverC5Vert's Avatar
SilverC5Vert
Could I also get it for VIN: 1G1YY32G7X5129205.
Thanks!
Old Aug 22, 2004 | 04:11 PM
2Grumpy's Avatar
2Grumpy
Default Thanks
Thanks for the quick reply....looks like I have a recall coming on the lower control arm washers.
Gene
Old Aug 22, 2004 | 05:07 PM
HD_Rider's Avatar
HD_Rider
Sir, info please on 1G1YY12G9Y5126408. Thanks, much appreciated.
Old Aug 22, 2004 | 09:22 PM
Sponge Vette
Thanks!
Open Recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 Open
VIN 1G1YY32G7X5129205
VEHICLE BUILD
Gross Vehicle Weight Rating : 1692 kg (3731 lb) Order Number : BNVFZ9
Build Date : 05/14/1999 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CJ2
C05 DL5
DL8 FE1
F45 GU6
IL3 JL4
JL9 K63
LS1 MM6
MN6 NB6
NC7 NG1
NK4 N37
QD4 R9Z
T82 T96
UL0 UV6
UZ6 U1S
U52 U75
VM3 V49
V73 XGG
YGH 1SA
13U 19I
193 41T
for some reason not everyones description of their options is listed. Go here to see the list.Options for 99 Vette
Old Aug 22, 2004 | 09:25 PM
Sponge Vette
Recall Notice:
VIN 1G1YY12G9Y5126408
VEHICLE BUILD
Merchandising Model : 1YY37 -2000 CORVETTE HARDTOP
Gross Vehicle Weight Rating : 1639 kg (3614 lb) Order Number : CHVXDG
Build Date : 04/12/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AP9 - PARCEL NET AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS C60 - AIR CONDITIONING
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE3 - SPORT SUSPENSION FE9 - FEDERAL EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IP3 - TRIM INTERIOR DESIGN - AR9
JL4 - ACTIVE HANDLING SYSTEM JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI, V8
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NF2 - FEDERAL EMISSION SYSTEM, TIER 1 NK4 - LEATHER WRAPPED STEERING WHEEL
QG1 - PAINTED ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
TR9 - LAMP GROUP T96 - FOG LAMPS
U73 - FIXED MAST ANTENNA VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SA - OPTION PACKAGE - BASE
19I - INT EBONY INTERIOR TRIM 193 - BLACK LEATHER TRIMMED SEATING SURFACE
41U - BLACK
Old Aug 23, 2004 | 08:11 PM
SilverC5Vert
Thanks!
Old Aug 15, 2023 | 05:00 PM
Charles Ackerman's Avatar
Charles Ackerman
1st Gear
Sponge,
Is it possible to get RPO codes via my vin# 1G1YY32GXW5113613 Built on 12/97? 1998 C5 Convertible
Thank You in advance,
Charles A.
ernie22@sbcglobal.net
Old Aug 18, 2023 | 11:09 AM
jackthelad's Avatar
jackthelad
You do know your replied to a 19 year old post?
Old Aug 18, 2023 | 01:55 PM
hyperv6's Avatar
hyperv6
Originally Posted by Charles Ackerman
Sponge,
Charles A.
Better to tell you how and where to get his info.
Go to the Corvette Museum web site and they can get you the window sticker and build sheet for your car printed right from factory.
If you don't want to pay the $90 you generally can remove the front bumper and find in the front bumper beam the build sheet is stuffed in it from the factory unless someone has already removed it.
Old Aug 20, 2023 | 04:01 AM
Closing this thread, but check here:
The RPO Code Label (Service Parts Identification Label) in a 1998 Corvette is located on the underside of the rear, left storage compartment cover (on the driver side) of the car in the early production models.
If for some reason the sticker is missing, go to your local dealer and ask them to run a report for you which will not only give you the RPO codes, but also the norm on date as well as the maintenance history that has been performed by a dealer.For an explanation of what the RPO codes stand for, just do a search for C5 RPO codes.
To born on date
