Help with a Code B0441
Old Jul 12, 2004 | 01:43 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Default Help with a Code B0441
I'm getting a DTC B0441 Left Actuator Out of Range . What is a actuator? I have also been getting a DTC B0361 Left Actuator Feedback Short to GND . That is when it seems to be blowing fuse 19. When the fuse blows, I get a ton of codes.Sometimes when I replace the fuse it blow it as sone as youe start the car. Then sometimes it will drive fine for awhile. Any thoughts? What is the actuator?
Old Jul 12, 2004 | 02:58 PM
CAPN17's Avatar
CAPN17
You have a short circut, stop replacing fuses and find the short before you incur some serious electrical damage to a computer.
Old Jul 12, 2004 | 05:59 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
The code is an A/C code the left actuator moves wene you change form heat to air if it goes out you will have hot air on the drivers side and cold air on the pass. Good luck mine is acting up too and its Hot in Ga
Old Jul 12, 2004 | 09:56 PM
JeepTJ's Avatar
JeepTJ
Thanks Capn17, good advise. Looks like she's going to have to go to the Local dealer. Say a prayer for me.
To Help with a Code B0441
