Blinker problem
Old Jul 12, 2004 | 05:26 PM
N2SPEED's Avatar
N2SPEED
Default Blinker problem
Has anyone had problems with their blinkers. Every once and while my blinkers quit working. Is this a question for tech? Thanks for any help.
Old Jul 12, 2004 | 05:30 PM
My blinkers work just fine. Perhaps you have an intermittent short somewhere if they are only causing you a problem part of the time. Could be a loose bulb also.
Old Jul 12, 2004 | 05:48 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
I havn't had any problems but I have heard if you turn the flashers on and off that might help. good luck
Old Jul 12, 2004 | 08:47 PM
VLVETTE's Avatar
VLVETTE
Happened to me the night I bought her.
Old Jul 12, 2004 | 11:15 PM
Batcar's Avatar
Batcar
Default See This Thread
http://forums.corvetteforum.com/showthread.php?t=858562
Old Jul 13, 2004 | 03:55 AM
bobsY2Kvette's Avatar
bobsY2Kvette
Happened to me several times, It is most likely a flasher problem. Try hitting the flashr button and letting it cycle a few times. For me, it seems to alleviate the problem
Old Jul 13, 2004 | 06:30 AM
ooh yeah's Avatar
ooh yeah
Hazard switch AFU
Old Jul 13, 2004 | 10:07 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I've have the same problem. Every once in awhile EITHER my left or right does not work. Several minutes later everything is ok. It is a mystery. All the bulbs are ok and I've had no problem with the fuses. It's weird that it happens to both turn signals and only rarely. Let me know if you find a solution.
rr
Old Jul 13, 2004 | 10:54 AM
Vetteguy53081's Avatar
Vetteguy53081
Try the cheap approach, replace the bulbs first, if no results, sounds like it may be a shorted hazard switch. This one will cost in labor.
To Blinker problem
