Check Engine Light + Reduced Power!?!
Old Jul 12, 2004 | 06:48 PM
SMX's Avatar
SMX
Default Check Engine Light + Reduced Power!?!
I was driving into work today and came to a stop at a red light. All of a sudden my car sorta bogged down... CHECK ENGINE light came on along with REDUCED ENGINE POWER on the DIC. Then the light turned green... I proceeded. Creeping along I pulled into a parking lot and shut the car off... looked around under the hood. I had to get to work so I started it back up... now it runs normal but the CHECK ENGINE light is still on. I need to drive home tonight... about 40 km (mostly highway)... any advice? Should I drive it home? Has anyone ran into this problem? Any information would be greatly appreciated. Thank you.
Old Jul 12, 2004 | 07:11 PM
c5freak's Avatar
c5freak
You absolutely need to check your error codes using the DIC. There are directions on how to do this on the forum. Write down the codes and post them on the forum. The Check Engine light can either be serious or a nuisance. It depends on the codes.
Old Jul 12, 2004 | 07:44 PM
SMX's Avatar
SMX
Default oops...
I accidently erased the codes.... before I wrote them down. I took the car for a 10 min drive to see if they would come back but nothing... back to normal. I guess I will have to wait and see on the drive home.
Old Aug 24, 2004 | 09:55 AM
noran01's Avatar
noran01
How do you check the codes via DIC? This morning on the way to work my check engine light came on, but i did not notice any power losee or anything and no message was displayed on the DIC
Old Aug 24, 2004 | 10:28 AM
pf728's Avatar
pf728
Its going to do it again, it happen to my 97. If i remember corectly it was the throttle possition sencor,or something to do with the throttle.
Old Aug 24, 2004 | 01:22 PM
Drive it home, just be prepared if it messes up again. Have a cell phone handy and some numbers to call (tow truck, dealer, etc). Good luck.
Old Aug 24, 2004 | 01:28 PM
Tino's Avatar
Tino
Default Check engine light
My buddy had something similar and it was a tire sensor that thought the tire was flat.
Old Aug 24, 2004 | 02:01 PM
WWK888's Avatar
WWK888
http://www.stengel.net/diccodes.htm
Old Aug 24, 2004 | 02:15 PM
MLEN1UM's Avatar
MLEN1UM
I had a similar problem - it would come and go. Turned out to be a loose coil wire on one of the cylinders... does that make sense? Sorry, it's been a while... It was diagnosed by the Chevy Corvette Mechanic. Not sure what codes I had - at the time I didn't know anything about codes.
Old Aug 24, 2004 | 02:18 PM
noran01's Avatar
noran01
During my lunch break i flipped through the manual and it kept pointing to fuel related issues. To make a long story short, the gas cap was not fully secure. Don't mind me, i'll go put the stupid hat on and sit in the corner. Thanks for the quick replies!
Old Aug 24, 2004 | 10:24 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Happened twice in my 98. The 2nd time it did not go away and turned out to be the Throttle Control Module
To Check Engine Light + Reduced Power!?!
