need to clean glue from dash - help
Old Jul 12, 2004 | 09:54 PM
BarkingSpyder's Avatar
BarkingSpyder
Default need to clean glue from dash - help
I've got a 2004 coupe that apparently had something glued or taped to the dash as it sat on the lot (it was there for 4+ months).
Any suggestions on how to clean the dash without maring the finish would be appreciated. I"ve tried the usual non abrasive cleaners and rubbing to no avail.
dan
Old Jul 12, 2004 | 10:18 PM
rcknusa's Avatar
rcknusa
I would first try some rubbing alcohol. If that does not work try nail polish remover.
Old Jul 12, 2004 | 10:20 PM
White00LS1's Avatar
White00LS1
6th Gear
I use goo-b-gone...you can get it at the checkout at Lowe's...works great on bugs too!
Old Jul 12, 2004 | 11:05 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Please do not try either one of these suggested products. I know from experience. GM plastics are not as robust as some of the Japanese makes. I removed an interior flag emblem from the waterfall area plastic behind the seat on my coupe. Decided to use a bit of rubbing alcohol to get the glue residue off and almost ruined the piece. Lucky for me I had some wet towels handy and got the alcohol off quickly before the plastic was destroyed. Nail polish remover is strong enough to remove paint and finish from furniture so do not use it on your dash.
My recomendation is to ty some store bought lighter fluid like Rosnol or Zippo. This stuff is nothing more than Naptha which is used to clean and remove furniture wax from furniture without taking the finish off. I have used it for years on all my cars for removal of tar, stickers, adhesives, etc. Work like champ and it will not damage the plastic. Great for the exterior paint surfaces to. Good luck.
P.S - I have a couple of small spots of glue on my dash up near the windshield base. I could not get the glue off so I decided to leave it alone and not mess with it. Destroying the dash is not worth the aggrevation.
Old Jul 12, 2004 | 11:07 PM
PaulaH's Avatar
0PaulaH
Former Vendor
I have heard of Go-B-Gone but have never used it..Try rubbing alcohol or a adhesive remover.. Good luck!
Old Jul 12, 2004 | 11:13 PM
mfrnka's Avatar
mfrnka
Goo-B-Gone works great. I used it to remove the double sided tape residue after taking off my Z06 screens. Give it a shot.
Old Jul 12, 2004 | 11:37 PM
Norris's Avatar
Norris
Try some WD-40 Just spray some on a wash cloth, then rub the area... Should come right off. Its also good for removing scuff marks....
Old Jul 12, 2004 | 11:44 PM
jrose7004's Avatar
jrose7004
Aproduct called Goof Off is good on a lot of things!
Old Jul 13, 2004 | 12:09 AM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
Old Jul 13, 2004 | 12:22 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Why don't you just take it back to the dealer and let them remove it?
Old Jul 13, 2004 | 07:05 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
dan
hair dryer loosen up it up by getting it warmed and then you use some sticky back brown wrapping tape to dab at it and get it to stick to the tape. Keep the heat on it but not hot just keep it warmed up. The tape will pick up the residue
Old Jul 13, 2004 | 09:54 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Old Jul 13, 2004 | 10:06 AM
Eddyd's Avatar
Eddyd
Default Glue on Dash
Old Jul 13, 2004 | 10:21 AM
WGreen's Avatar
WGreen
Cruise-In I Veteran
I can say from experience DO NOT use nail polish remover or acetone type cleaners as it will remove the finish from the part. I would try citrus based cleaners first.
Old Jul 13, 2004 | 10:41 AM
CAPN17's Avatar
CAPN17
GM parts sells a solvent for cleaning weather strip adhesive. The solvent is Tec 90 and it is carried in parts, I have used it to take off all forms of adhesive and never had any damage. Check with your near by Chev. dealer.
Old Jul 13, 2004 | 06:25 PM
LemansBlue's Avatar
LemansBlue
Default Do Not Use Nail Polish Remover!
Many nail polish removers contain acetone, which will damage most plastics. Denatured alcohol or goo be gone should do it. Good luck.
Old Jul 13, 2004 | 09:44 PM
BarkingSpyder
Thanks for all the replies .... I think I'll try the heat gun with some tape to see if that will remove it. If not I'll probably try the cleaner from GM that was mentioned.
I've used goo-b-gone before and know from personal experience that it is not save to use on many plastic products ... says on the can beware etc and to try on a small area first.
Solvents are a no-no ... the wd40 is an interesting idea. I used to use it to remove pine sap from cars ... but the smell
Thanks again..
dan
To need to clean glue from dash - help
