Throttle body bypass???
Old Jul 13, 2004 | 12:00 PM
Rons2ndC5's Avatar
Rons2ndC5
Default Throttle body bypass???
Awhile back I installed a throttle body bypass....Thats a good thing.... The bad thing is it just hangs there. I currently have it supported to the coupler with a long cable tie (one step up from bailing wire). Has anyone had this problem, and what is the fix.
Old Jul 13, 2004 | 12:37 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
It's pretty well documented, via scores of threads on this forum, the T/B bypass is pretty much a worthless mod. I'd take it off and hook up the coolant hoses to the T/B and pitch the bypass into the garbage can...Whalla---no more ugly plumbing..
Old Jul 13, 2004 | 12:41 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
You have to look hard to see mine...I was always concerned the hose or clamp would rub on the pulley, but it hasn't...yet anyways
One thing different with mine is, I replaced my little 3/8 diameter rad. hose twice ($30 from dealer) so I went with regular heater hose, doesn't have the nice factory bends, but isn't a problem no more.
Old Jul 13, 2004 | 01:11 PM
Unless you can find a different way to route the hose that would hide it under some other components, then you may be stuck with it just hanging there.
Old Jul 13, 2004 | 02:06 PM
Rons2ndC5's Avatar
Rons2ndC5
How did you support it?????
Old Jul 13, 2004 | 04:20 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
With a High Performance Hood Seal?
To Throttle body bypass???
