Ramps
So one option is to lift it, but I would feel safer with ramps. Any suggestions on which ramps to get?
Oh and I commend those people that built their own, but I am not getting under a heavy car with anything that I built...
thanks
Do a search under Tech Tips for a detailed description of changing the oil yourself. I think you'll see what I mean.
Hope this helps.
EDIT: BTW, you still need a good set of ramps for routine things like cleaning under the radiator shroud which, you will find, is like a vacuum cleaner for the street. Sucks up all kinds of trash. Rhino ramps come in different slopes. Get the ones that have the Corvette (and a truck?) on the packaging. Got mine at Wally World for about $15 each. They work great.
Good Luck.
Back up on a set of Rhino ramps. Using floor jack I jacked up the front and placed my other set of Rhino ramps under the front wheels.
It is a tight fit but if you do it fron the drivers side you can do the filter and the drain plug without any problem.
I have a floor jack and stands already so I will be heading out this weekend to get the ramps.
thanks for the advice
thanks
Bob:
After you lower your car (and you will lower your car), you'll
need to be a little creative with lifting.
First, get yourself 4 good jack stand, one set of Rhinoe ramps (gray ones) an aluminum racing jack and four, 18" cuts of 2x12 boards
and don't forget the pucks.
Pep Boys has a sale on the aluminum jack and ramps. Drive up one th boards and either jack up or drive up on the ramps.
Or better yet, invest now and buy a Qwik-Lift. (Do a search)
Convince you wife it's a safety issue.
Although I crawl around under my car for everything, for oil changes
I just drive down to my local corner lube shop with my 6.5 quarts of
oil, filter and drive over their in-ground shop. No lifting and is level.
I can't be bothered disposing of the oil and making a mess in the garage. But that's just me.
...George
Oil Changer
Rhino Ramps
