StuzVette sometimes read low but seems to warmup and actually lower along witht he heads-up display...
...on the other hand the HUD view in Jami's C6 doesnt read correctly...
Don't worry I trust my dealer a lot with my car and have a great business relationship with the sales manger and the owner sister who calls after everytime I get the car regularly serviced or worked on for the gas gauge. They want to get to the bottom of the problem also.
She isn't by chance one of your recent avatars is she?
my problem sucks when i fill tank up with 89 octane a couple minutes later it goes to empty and the check gages light **** on but wen i turn it off and then back on its fine so i have to get it checked out but good luck with yurs
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Man talking about bringing a thread back from the dead. here is some more info from Ken Fichtner, my car may have a 2002 sending unit since it was built in the last few weeks of the 2001 production run.
11) 2002 thru 2005 Erratic Fuel Reading – NEW 3/25/05
2002, 2003, 2004, 2005 Chevrolet Corvette and 2004-2005 Cadillac XLR (Y-Body) Fuel Gauge is Erratic
Message VSS20050445
General Motors is in the process of redesigning the fuel tank sending units in both of the subject vehicles. A new part number has been released but it is not yet in stock. Some dealers have attempted to order the new parts 88967315 or 7316 and they have been told that the parts are not yet available. The new parts have an improved ink coating which will provide improved resistance to fuel contamination and correct fuel sender over travel which is the primary cause for the fuel gauge being erratic. Fuel Modules should not be replaced for complaints of erratic fuel gauge. The fuel sender card is the only part required.
Until the new fuel sender cards are available, the 2004 card is available and can be used. Part number 10310028 left side and 10310103 for the right side will operate in all 2002 through 2005 applications. However it does not have the improved ink path. In cases where a customer insists on a replacement part, the 2004 part can be used although it is the same part that is currently in their car. Availability is expected by the end of April. A bulletin will be released with correct part numbers as soon as the parts become available.
