ls1 edit? hypertech? predator?
Old Jul 14, 2004 | 07:34 PM
doug estep's Avatar
doug estep
Default ls1 edit? hypertech? predator?
what does the ls1 edit do that a predator, etc can't do?
i'm confused on how they differ. i'd like to have something i could plug in to show me codes,tune it and make it shift firmer etc.
how much can you expect to gain performance wise? do you have to reset everything if you make a mod?
thanks,
doug
Old Jul 14, 2004 | 08:26 PM
bobsY2Kvette's Avatar
bobsY2Kvette
thanks,
doug
LS-1 Edit is a software whereby you can adjust all electronic parameters that govern the the car's operation. Air fuel mixture, shift points, shift strength, tire size, timing, power curve, rev limiters, sensor strength and calibration ....Literally anything in the cars electronics. To My mind, the best bang for the buck.
I had my 2000 A4 coupe dynotuned with LS-1 Edit by the Vette Docs early this year and i can tell you, It is the best $299 I ever spent. I picked up 18 rwhp and 27 rwtq from jut the edit. But forget the numbers.... the difference in sotp feel was incredible. I cant wait to mount my headers so i can get it done again and feel that incredible boost
Old Jul 14, 2004 | 08:53 PM
birch64's Avatar
birch64
for $299.00 what did they do? was that a basic street tune(trans and shift points) or a dyno tune where they do everything (air/fuel fans, timing)?
Old Jul 14, 2004 | 09:01 PM
TeamSpeed's Avatar
TeamSpeed
You might get some decent responses in the Scan and Tune section. Also, there is a new kid on the block regarding logging and changing your PCM, do a search for VCM Suite...
This is what I plan on buying very shortly!
Old Jul 14, 2004 | 09:23 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
I'm putting headers on this fall and then headed for Dynotech Engineering in Ft. Wayne, IN for what they call a PCM Calibration. They didn't give the software a name.
As it was explained to me they will put it on the dyno for the afternoon and can do as many as 15 dyno pulls as they tune the PCM. They specifically said it was not called LS1 Edit. I've heard extremely good things about this organization. With the basic bolt on mods that I've got (BW/Drilled Fog Lite Ducts, soon to be LG Pro LT's w/ no cats, and GHL), I've been told I could see 30 or more rwhp out of the program as I started out bone stock and have 33k miles at this point.
But they're quoting me $500-550 for the day depending on how many dyno pulls it takes to max it out.
Any thoughts? I guess I'm just as confused. Especially w/ the $299 thing.
Thanx.
Michael
Old Jul 14, 2004 | 09:51 PM
bobsY2Kvette
Everything, and I mean everything. Carmen spent 3 1/2 hours on my car and did 8 pulls. tweaked a little and did a pull, treaked some more, did another pull till he had it just where I wanted it
Old Jul 14, 2004 | 10:02 PM
TeamSpeed's Avatar
TeamSpeed
That's funny, I live in Ft Wayne. $500 from Dynotech sounds pretty steep. I wonder if LPE in Decatur still just does tuning. It would be about the same price, I bet.
Old Jul 14, 2004 | 10:55 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
I had Violater do an LS-1 Edit to my 2000 coupe at the Cruise In. Now I get better gas mileage.
Old Jul 14, 2004 | 11:31 PM
bobsY2Kvette
Thanx.
Michael
That $299 was a Forum special so i dont know if your 500 is a bargain or not for your area. I think it was about 100 bucks lower than his normal price. If you look up Vette Doctors on the left and give carmen a call, I am sure he would be happy to talk to you and give an opinion. I would also check the midwest forum and see if anyone there has any good experiences and prices Good luck
also I would get a clearer picture from Dynotech on what they will do. sounds like it might be an LS-1 Edit, But then again, It sounds like it might not be
Old Jul 14, 2004 | 11:44 PM
CN RED's Avatar
CN RED
Not to jump on your post but I'm still interested in people who have used the hypertech and or the predator. I don't believe they could be that much different. Please, I want to make a conscious decision, so I need as much imput as I can about all three products.
So for the originator of this thread and many others that might have the same issue.........Thanks in advance,
CN RED
To ls1 edit? hypertech? predator?
