Interior rearview mirror fix
Old Jul 16, 2004 | 10:33 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Default Interior rearview mirror fix
Anyone know a fix for this problem on my 2000 Vert A4? Every time I hit a rough spot (RR tracks, etc.) the mirror drops down and has to be readjusted.
Old Jul 16, 2004 | 12:41 PM
TheHammer's Avatar
TheHammer
I have a 97, and rearview mirror seems to sag all the time and vibrates when I am idle. It will not stay in the position I put it in. It is like a 1/2 inch loose movement up and down.
Old Jul 16, 2004 | 12:44 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
my 97 did that too.
all you need to do is snug up the little allen wrench bolt.
now that I think about it, it may be a torx bit. I am at work so I cant tell you for sure.
Old Jul 16, 2004 | 12:52 PM
ROD BROWN's Avatar
ROD BROWN
Default Rear View Mirror
First ,determine if the base is loose.If it is go to PEP BOYS or any parts house and purchase a special adhesive made for the installation of rear view mirrors.Clean the old adhesive off with a razor blade and follow the instuctions with the adhesive.It worked great for me.No more vibration! I learned about this fix here on the forum . :flag
Old Jul 16, 2004 | 02:16 PM
BayouVette's Avatar
BayouVette
I just had mine rattle completely off twice for lunch..
All that from a little 10" solobaric kicker..
Old Jul 16, 2004 | 02:41 PM
mrtoner's Avatar
mrtoner
The mirror adjusts on two ball sockets. One of them has become loose in one direction.
A simple fix is to grab the rod between the mirror and the window, and turn it in the window socket 90deg. Then, readjust your mirror
It should now be as tight as new...
Old Jul 16, 2004 | 06:06 PM
sxeC7's Avatar
sxeC7
Thanks mrtoner,
Sounds like it should work, I'll give it a try.
Old Oct 25, 2014 | 11:21 PM
00PewterVert's Avatar
00PewterVert
Cruising
Mrtoner, that worked perfectly. Thank you for that great suggestion.
Old Oct 25, 2014 | 11:53 PM
A really old thread, but some very good info.
Old Oct 26, 2014 | 07:00 AM
rsl2715's Avatar
rsl2715
Will give this a try.R
To Interior rearview mirror fix
