Column Lock survey
Old Jul 17, 2004 | 11:51 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Default Column Lock survey
trying to survey who has had problems
Old Jul 17, 2004 | 12:21 PM
2KFRC5's Avatar
2KFRC5
Bought new, Sep. '99
Column locked, Aug. '00. Repaired by dealer (Warranty).
No CLB, no re-occurrence. (So far)
Old Jul 17, 2004 | 12:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I didn't vote...as there is no choice for "column lock failed...but stuck in the unlocked position".
Old Jul 17, 2004 | 12:26 PM
HummelS's Avatar
HummelS
Ditto
Old Jul 17, 2004 | 02:30 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I have an '04 auto. No problems yet. Still wondering if mine is included in the recall. I am getting conflicting reports.
Old Jul 17, 2004 | 02:34 PM
LuS1fer's Avatar
LuS1fer
The later autos had the column lock deleted so no.
Old Jul 17, 2004 | 02:40 PM
BigJoe's Avatar
BigJoe
for sure '04 A4s have no lock to get stuck. Not sure about '02 and '03. To test, take the key out and try to turn the wheel. If it turns even a little bit, you will have no problems with CL. However this ONLY applys to A4s. ALL MN6s have the lock.
Old Jul 17, 2004 | 03:08 PM
Mike2013's Avatar
Mike2013
That's what I thought. Read Ken's latest. According to GM '04 auto's are included in the recall.
Old Jul 17, 2004 | 04:20 PM
Had several messages of "Pull Key, wait 10 seconds" on my '99. But, no problems with my '00 so far. Got the CLB to install, so hopefully won't have any on the current car.
Old Jul 18, 2004 | 12:17 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
For the millionth time (well, maybe not that many), 2001,2002,2003 and 2004 automatic transmission cars do not have a steering column lock. Therefore, no steering column lock means no lock up problems. Why-Oh-Why are people who have Corvettes which fall into the above group of cars still wondering if they are going to have a lock up problem or when are they going to get a recall notice from GM??????
For what its worth, last year I had my Chevy dealer do the recall "fix" on my '98 A4. The "fix" makes it impossible for the column to lock as a plate or something is placed in the steering column making it impossible for the pin to drop into the column, which causes the lock up. Too bad the same "fix" can't be used on 6 speeds---with a M6 your only safe bet is to install a column lock bypass
Old Jul 18, 2004 | 12:29 AM
mapman's Avatar
mapman
I have a 2003 A4. It will be interesting to see if any 2003 A4s report problems as there is no column lock.
The placebo effect.
Old Jul 18, 2004 | 11:39 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
There is a new thread on the Forum this morning that reports that the installation of an aftermarket CLB has caused other types of prolems. I am not advocating that the installation of a CLB is the proximate cause of any other problems. I would just suggest if anyone wants a balanced input that they read this other thread.
I have had no problems but I did install a CLB on my MN6
Old Jul 18, 2004 | 11:54 AM
Joe's Eray's Avatar
Joe's Eray
Mine locked up on me numerous times. After jerking the wheel off the steering column and twisting the key at the same time, she broke loose. I got sick of it and finally got the CLB.
To Column Lock survey
