cags eliminator
Old Jul 18, 2004 | 05:46 PM
98vert6spd's Avatar
98vert6spd
Default cags eliminator
dont spend the 20 or 15 on the eliminator clip
i bought 5 of the 2.2 ohm .5 watt resistors for 99 cents and plugged one into the clip bingo no more cags
hahah best mod under 1 dollar
Old Jul 18, 2004 | 05:49 PM
Automag928's Avatar
Automag928
I just push the big pedal on the right down a little more...
Old Jul 18, 2004 | 05:51 PM
Sho-nuff's Avatar
Sho-nuff
From: When I say who is the masta you gotsta say Shonuff
Good job. CAGS got me three times daily and just had to go.
Old Jul 18, 2004 | 06:27 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Just drive the car like a Corvette and the CAGS will never once get in your way. You'll never klnow it's even there if you would just drive it and stop shifting the car at 1200 rpms.
Old Jul 18, 2004 | 06:29 PM
Glennm27's Avatar
Glennm27
Just drive the car like a Coirvette and the CAGS will never ever interfere. Stop shifting the car so dam soon.
Old Jul 18, 2004 | 06:42 PM
chocoholic's Avatar
chocoholic
Even cheaper is to simply not change gear during the 5 MPH window that CAGS operates in or, as mentioned, just press the go pedal a little bit harder.
Old Jul 18, 2004 | 07:11 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jul 18, 2004 | 07:43 PM
Oldvetter's Avatar
Oldvetter
Ah, but water can get in your connector and change the resistance over time, then you will get a code.
The ones you buy (for all of $20) come with a stock, weather-proof connector.
Good luck !
Old Jul 18, 2004 | 08:37 PM
jerrymcb's Avatar
jerrymcb
Good luck !
And they also come with a plug for the solenoid to prevent
corrosion there.
Old Jul 18, 2004 | 08:53 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
HEAT HEAT HEAT
Watch your resistors change value with all that heat under the car. . .
There is NO FREE LUNCH
Old Jul 18, 2004 | 09:06 PM
C5GARY's Avatar
C5GARY
NO It will not change value over time.. what
It works fine. Mine has been there for over 4 years now.
A resistor plugged into the plug is going to get just as hot as a resistor molded(?) in a plastic plug!!
BTW, it is a 2.2Kohm resistor, 1/2watt(just so the wires fit into the plug securely).
Gary
'99 coupe
Old Jul 18, 2004 | 09:16 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The DIY'er is alive and well. YES!!!!!
Old Jul 18, 2004 | 09:20 PM
98vert6spd's Avatar
98vert6spd
next project is heads and cam with headers and cats
To cags eliminator
