[Z06] side trim spear
Old Jul 18, 2004 | 06:27 PM
RoHo's Avatar
RoHo
Default side trim spear
Would any of you guys know how the side trim spear coming out of the side scoop is attached, or maybe I should ask if you know how to remove it with out affecting the paint under the spear?
Old Jul 18, 2004 | 06:33 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I think it's just adhesive tape, but I've never done it. There are lots of members that have removed the bsm's...someone will chime in for ya.
Old Jul 18, 2004 | 07:11 PM
CAPN17's Avatar
CAPN17
The BSM are held on with double sided tape. A piece of fishing line and warm the BSM up with a hair dryer, then use the line like a saw to break the bond. Once they are off you have a glue clean up to do.
To side trim spear
