[Z06] Hood Seal
Old Jul 18, 2004 | 09:38 PM
Z06JAX's Avatar
Z06JAX
Default Hood Seal
Do these hood seals do any good? Whats the good, bad and ugly of this product?
Old Jul 18, 2004 | 10:00 PM
atz06's Avatar
atz06
Got it from Auto zone. $16 good for two Vettes. Keep the engine bay a little bit cleaner. No big deal and no brainer.
Old Jul 18, 2004 | 10:07 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Keeps water and dirt from entering the engine compartment. Good idea for cars with an open intake.
Old Jul 18, 2004 | 10:15 PM
CJS's Avatar
CJS
The bad is that GM engineers left it off the car for a reason. It lets more air in an out of the engine bay, keeping temperatures colder and thus colder air is going to an underhood air cleaner.
GM did not just "forget" to put a seal on there. Your choice, cleaner engine, or better performance. Just my common sense view.
Old Jul 18, 2004 | 10:29 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Here is what it looks like installed, works great.
Old Jul 18, 2004 | 10:38 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Old Jul 18, 2004 | 10:42 PM
xilr8n's Avatar
xilr8n
They included it on the C6.
Old Jul 18, 2004 | 10:59 PM
Shylor's Avatar
Shylor
So the air entering the nose inlets and from underneath the car isn't enough? I find that hard to believe.
Old Jul 19, 2004 | 03:09 AM
CAPN17's Avatar
CAPN17
With the Motor City Mold hood, I am not worried about the loss of flow from an unsealed gap. On the filp side, my engine bay stays much cleaner with out the debris forced in through that vent crack you say GM enginered there.
Old Jul 21, 2004 | 07:12 AM
CJS's Avatar
CJS
Look, I doubt that putting the hood seal on a C5 causes any serious air flow recuction problems, because so many people do it without apparant harm.
But What I am saying is that GM Wind Tunnel tested and engineered the air flow of the C5 for inside the engine compartment, and outside the car, flow characteristics.
I believe that the open front hood gap allows air to flow up and out of the engine compartment. So air flow from the front underside of the car can then have an Escape route, Up and over and around the Air Cleaner and then up and out of the hood gap. In fact at speed, air should be positively sucked out of the gap.
Without an escape outlet air does not and cannot flow. The front of a C5 engine compartment above the shroud is pretty much sealed off, so flow in that area may be limited. Maybe the gap ,with out the seal, increases flow and reduces temperatures at the air cleaner by say 10%. If this is true, It would be a real effect, but the average person would not notice, only the hard core drag racer looking for tenths off the time slip.
Old Jul 21, 2004 | 07:49 AM
Cruncher's Avatar
Cruncher
Default Hood Seal
I treid the hood seal twice. It would never stick in the area where the front of the engine compartment formed a slight "V". A body shop tried using their adhesive...it still did not work. Other than looking nice when I first put it on, it did not work once I closed the hood...everytime I closed the hood, it made the hood seal that much worse. It seems that the seal never wanted to make that bend in the middle of the engine compartment (where there is a slight "V" shape).
Old Jul 21, 2004 | 07:50 AM
TLM's Avatar
TLM
Keeps the engine dry and clean
Old Jul 21, 2004 | 09:43 AM
Thunder22's Avatar
Thunder22
why is that a concern? it's an engine, it should get dirty....
Old Jul 21, 2004 | 10:05 AM
cj68's Avatar
cj68
I bought the aftermarket hood seal and did not like the way it would have looked on the car, so I sent it back.
Recently, I ordered the GM seal strip ($17 and is the same one that is on the sides of the hood) and it works and looks great. It is not a big bulbous piece of plastic like the ones sold in catalogs, and therefore is easy to install and mold.
When I installed it, I made sure to stick it as close to the top edge of the bumper cover, without actually touching the edge. Since this seal is much smaller than the aftermarket ones, you have to adhere it to the vertical surface of the bumper cover rather than the horizontal, to make sure that you have a good seal.
Chris
Old Jul 22, 2004 | 09:29 PM
Dave1998's Avatar
Dave1998
Can I get the GM part #? I want 1. Let me know what to ask for
thanks
Old Jul 23, 2004 | 09:40 AM
Gonzo's Avatar
Gonzo
I used 3M 2 sided heavy duty tape (holds up to 5 lbs). Just fold it into the corner formed by the nose and the inside lip, and place the seal where it goe's. No problems since.
Also prep the area with denatured alcohol to allow a good STICK.
Mine fell off several times before I did this
Old Jul 23, 2004 | 10:32 AM
cj68's Avatar
cj68
thanks
Dave,
I don't have a part number, but if you call Lambert Pontiac/Buick/GMC in Ohio (this is an old and well known F-body forum parts contact) @ 888-720-7718 and ask for Steve, he will hook you up.
Just tell him that you want 1 piece of the seal that runs along side of the fender inside the engine bay. They are a great place to deal with and have excellent prices (I think they sell to the clubs/forums at 10% over cost or something like that; I know that their prices are as good or better than GM Direct).
Let me know if you have any problems or questions.
Chris
Old Jul 23, 2004 | 11:24 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I find it odd that after this many posts no one has commented on the tremedous hp gains.
To Hood Seal
