Fuel Rail Covers
Old Jul 18, 2004 | 10:33 PM
jjk2509's Avatar
jjk2509
Default Fuel Rail Covers
I am about to get my fuel rail covers painted. I am also wanting to install some AFR heads and a LS6 intake manifold over the winter. Does anyone know if I change my heads and intake manifold from stock to a LS6 intake and AFR heads, will the stock fuel rail covers still fit?
Thank for any help.
:flag
Old Jul 19, 2004 | 01:51 AM
jjk2509's Avatar
jjk2509
ttt
Old Jul 19, 2004 | 02:26 AM
lowdowndirty's Avatar
lowdowndirty
They will still work. The outside dimensions will not change enough to effect the fuel rail covers.
Old Jul 19, 2004 | 07:53 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
However, be advised that if you upgrade to the FAST intake, the fuel rail covers will need to be modified.
The FAST intake has 'larger' flow areas that hamper the ability of attaching the FRC's to the rails without cutting the FRC '****' to allow clearance.
Old Jul 19, 2004 | 07:58 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Old Jul 19, 2004 | 08:05 AM
jjk2509's Avatar
jjk2509
Default Fuel rail covers
Thanks for the help. Looks like I can spend the money on the covers
and still be ok.
Old Jul 19, 2004 | 01:40 PM
Good luck with the covers. Should work and make a nice change for your engine compartment.
To Fuel Rail Covers
