Dentist Drill Sound Question...
Old Jul 21, 2004 | 02:42 PM
Perceval's Avatar
Perceval
Default Dentist Drill Sound Question...
I've noticed from time to time, mostly while parking, the car makes a high pitch drill sound. Sounds very similar to a dentist's drill. It would appear to happen more if the car is hot, and never for more than 10 seconds at a time.
Is this a normal cooling sound of the LS1, and should I be concerned?
Old Jul 21, 2004 | 03:02 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
AC compressor?
Old Jul 21, 2004 | 03:12 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
when you first start it you can hear the air pump...other than that I dont know.
Old Jul 21, 2004 | 03:13 PM
Perceval's Avatar
Perceval
Happens regardless if I've had the AC running or not. Will also happen from a cold start. (More often if the car's already hot from sitting in the sun).
I don't know enough about the LS1 to know for sure what the air pump sounds like.
Old Jul 21, 2004 | 03:15 PM
Humy's Avatar
Humy
Old Jul 21, 2004 | 03:17 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Sounds like the cooling fan kicking in. Its not suppose to have a high pitched sound though, maybe its starting to go. Might want to have it checked out.
Old Jul 21, 2004 | 03:27 PM
Tomstoy's Avatar
Tomstoy
Sounds like might be fuel pump.
Old Jul 21, 2004 | 03:29 PM
vettatude's Avatar
vettatude
That's the AIR pump running. It runs on cold start up and occassionally other times, even after warm up.
Old Jul 21, 2004 | 03:50 PM
bsmith's Avatar
bsmith
how you described it is pretty good, I bet a dollar that is what you hear.
Old Jul 21, 2004 | 05:18 PM
Dirty Howie's Avatar
Dirty Howie
I feel qualified to answer this question (Macinamouth).
It is the little rogue leprechaun dentist that is causing your afliction.
Please see your dentist every 6 months
Old Jul 21, 2004 | 06:07 PM
This would be my guess also.
To Dentist Drill Sound Question...
