Help! Gotta get this off!
Old Jul 21, 2004 | 07:51 PM
BigGunzCP's Avatar
BigGunzCP
Cruising
Default Help! Gotta get this off!
Last night I stayed at gf's new place. She has a large tree next to her driveway. I parked as far as I could away from it, but not far enough I guess. There is sap all over my car! Early this mornig it was dark and I didn't see it, but after work it had dried.
What is the best way to remove this stuff? Its obviously very sticky and I don't want to scrub too hard on my black paint. Help please!
Old Jul 21, 2004 | 07:53 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
CLAYBAR. You can purchase it at almost any auto shop
Killrwheels's Avatar
Killrwheels
wax will usually remove , wd40, alcohol, and even a polish as necessary.
Old Jul 21, 2004 | 07:57 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Default tree sap
try this its from the detailing dude "I could remove the Tree Sap with Butter or Margarine. I went out and bought some Butter, let it sit on the sap for a bit and it was beginning to soften the sap. After 45 minutes it seemed to have done the trick." http://www.thedetailingbible.com/336846.html
hope it help he has a great web site
Old Jul 21, 2004 | 08:00 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Claybar & Z6...
Old Jul 21, 2004 | 08:05 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
I'd try car soap and water 1st!
Old Jul 21, 2004 | 08:11 PM
C5 RACNG's Avatar
C5 RACNG
Originally Posted by BWP 5P
I try car soap and water 1st!
Old Jul 21, 2004 | 09:21 PM
don7790's Avatar
don7790
easy with the clay bar.
Old Jul 21, 2004 | 09:26 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
The manual is very specific against using any petroleum based solvents on the paint
So I wouldn't use WD40.
Sorry to hear about the mess, but, Claybar will get it, but buy enough to do the job. You'll probably need 4 or 5 of them as the sap will wear them out quick.
Good Luck!
Old Jul 21, 2004 | 09:31 PM
CE2004's Avatar
CE2004
At my previous residence, I had pine trees lining the driveway. Clay Bar worked magic and took that mess off of my paint. (Thankfully, it wasn't a Corvette, but it still ticked me off!)
Old Jul 21, 2004 | 10:25 PM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
I agree with Butter first then if that does not work WD-40
then clay, wash and rewax
Old Jul 21, 2004 | 10:35 PM
Vettlldo's Avatar
Vettlldo
Oh my gawd...another clay bar discussion! :ack
Old Jul 21, 2004 | 10:46 PM
BigGunzCP's Avatar
BigGunzCP
Cruising
Thanks for the feedback, guys. I'll make sure to stay away from that tree from now on
Old Jul 21, 2004 | 11:27 PM
c3&c5 vets's Avatar
c3&c5 vets
a lot of us have used wd-40 and i've never heard anybody say it damaged the paint.
Old Jul 21, 2004 | 11:43 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Some saps come right off with soap and water. Use the mildest solution first then go more drastic. Try a small area first then when you know what works do the whole car. Let us know how it goes. And you should have clay bar you'll be amazed at what it'll take off without harming the paint. Good luck.
Old Jul 22, 2004 | 07:41 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
Bug and Tar remover?
Old Jul 22, 2004 | 07:47 AM
V8USA's Avatar
V8USA
To Help! Gotta get this off!
wrustywrench's Avatar
wrustywrench
a good wash job will do it,,,,you wont need the clay bar,,,I worked at a gas station for years when younger and wash many tree sapped cars with soap and water.. aitn no big deal. wax the car after and it make the next time easier
Old Jul 22, 2004 | 08:05 AM
exile's Avatar
exile
Old Jul 22, 2004 | 11:36 AM
SUPERCRUZ's Avatar
SUPERCRUZ
I agree with those that recommend washing the car first. Another recommendation that his worked for me is to use hot water with your car wash. This seems to have a melting effect on the sap and helps wash it away. I would try this before usign any chemical or clay bar process. The most difficult tree sap I have found to remove is Pine Tree sap. That stuff is like glue and water will not disolve it. Good luck.
