[Z06] Stock Stereo Sucks
Read this:
https://www.corvetteforum.com/techti...=120&TopicID=1
*sigh*.....call them whatever you want, "tweeters" or not, they are designed to reproduce high frequencies, I never said they were as good as aftermarket components. You are not reading my posts, you are too busy trying to disect them and sound intelligent yourself. Read what I'm posting before you reply. I agreed with what you said before, however I did say that for factory, its not that bad, yes the tweeters could be improved, but I can think of hundreds of cars that would love to have 8's in the doors from the factory, its always give and take. When it comes to an aftermarket setup, the Vette has spacious doors which will accomodate a large component set, and for the record, you are wrong about tweeters needing to be at ear level or in front of the occupants. Almost all of the winning pro sound cars have kick panels with tweeters mounted in them, which down near the floor. You will get a higher soundstage by raising the tweeters, but not a more accurate one. High frequenices are very directional so if the speaker path lengths are not optimized, especially with mids and highs, you will have a left or right side bias. And before you mention it, time based correciton is not the cure, its a band aid and not a very good one.
For a guy that was sponsored by Phoenix Gold, you sure don't seem to remember much about proper car audio, unless you're just holding back here to keep it simple for everyone else here. If you honestly competed you should know more about proper stereo imaging. Maybe you've just been out of the loop for too long.
A great stereo (I mean great) makes a great car even better. Nothing compares to a full throttle 1-2-3 run when you have great music m-o-v-i-n-g through your body.
If you are willing to listen to someone who has been there and done that - I installed a great system in my first 01 C5 coupe after a bit of trial and error. Don't compromise, but don't go overboard.
First - the stock HU works fine. Search 99HT archived posts to understand connecting an external amp.
Second - You need excellent front speakers with exceptional power handling. Go get 1/2" MDF from Home Depot. Go get Dynaudio MKII 7" components. Make a baffle with the MDF and make brackets to angle the tweeters forward toward the windshield. The pass speaker should face the drivers side of the windshield, the passenger the opposite.
Third - Get a JL Audio 300/4 and mount it under the passenger seat. Use 2 channels to power the Dyns.
Fourth - Purchase a JL stealthbox and drop in the rear well (remove for track events, etc). Bridge 2 other channels from the JL and wire it up. Cross it over at 70 hz.
Fifth - disconnect the rear speaker wires - they are terrible.
Set the gains and get ready to enjoy some fantastic sound quality from a stock appearing system.
Good for you...sorry my opinion doesn't count though.
Good luck with your tweeters "down near the floor".
Delco couldn't make a decent radio if its existence depended on it. Unfortunately GM has kept that from happening. At least it helps keep the aftermarket going.
Well, I have yet to see you make a credible or useful post so I'm way ahead of you.
If you have ever heard a properly set up stereo, you would not be making comments like this. Tweeters "near the floor" have been working very well for pro audio competitors for well more than a decade now.
I'm not a big fan of Dynaudio, but to each his own. Dyn's sound a little bland and laid back. I've owned a set before and they just weren't the sound I was looking for. I'd take a set of DLS, Focal, or CDT components over Dynaudio anyday.
Take this silly debate to the audio section. Tell them how great a "tweeter at the floor" setup is.
Take this silly debate to the audio section, or better yet the sounddomain.com forums. Tell them how great a "tweeter at the floor" setup is.
Please. Better to take the money you'd pump into building a high end sound system and put it towards H/C or S/C, IMO.
Others have told me that the slight whine of their S/C's is "music to their ears."
