99 fog light adjustment!
Old Jul 22, 2004 | 09:40 PM
jperez's Avatar
jperez
6th Gear
Default 99 fog light adjustment!
How can I adjust my fog lights on my 99?
Old Jul 22, 2004 | 10:20 PM
tipcapman's Avatar
tipcapman
Easy.... find the round hole in the bezel adjacent to the fog light. If you look into that hole, you will see a Torx head fastener. It is a T15.
Turn that screw to adjust the fog light elevation.
L
Old Jul 22, 2004 | 10:35 PM
Oldvetter's Avatar
Oldvetter
I adjust the fog lights' centerline to be on the lower low beams "light line", at about 25-30 feet, it works great for me.
I leave my foglights on all the time with the low beams, it lights up sides well. I also used 50 watt bulbs, instead of stock 35/37 watts.
Old Jul 23, 2004 | 12:38 AM
jperez's Avatar
jperez
6th Gear
thanx for the info!! How hard is to change out the bulbs?
Old Jul 25, 2004 | 01:46 PM
Oldvetter's Avatar
Oldvetter
Not too hard. Raise your lights by turning the mechanical bypass wheel, and reach in there, you may have to remove the bezel around your headlights, depending how big your hands are.
Remember use gloves or do not touch bulbs with your hands, as the oil could burn them out prematurely.
Old Jul 25, 2004 | 03:03 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
I need some more explanation, please :
where do I find the mechanical bypass wheel ? ? Are the headlights off at this point in time and the doors closed ? ?
Thanks in advance for your further explanation
Old Jul 25, 2004 | 04:17 PM
2KFRC5's Avatar
2KFRC5
Raise the hood, black round **** just behind headlights. Turn to raise headlights, which should be off at this time.
Use caution while closing the hood with the lights up. No problem with mine, but I read somewhere that the hood might hit the raised headlights.
Old Jul 25, 2004 | 06:13 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Thank you sir. I hope I can return the favor.
Old Jul 25, 2004 | 06:52 PM
2KFRC5's Avatar
2KFRC5
Glad I could help. And you're welcome.
Old Jul 25, 2004 | 07:57 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
What are you talking about ???? what do the headlight have to do with a fog light adjustmenet??
you never have to touch the bulbs ??? so why even mention it...
there is a torq adjuster just to the side of each fog light... most foglights are aimed down from the factory because they are not aimed at all... once you crank UP the foglights they will actually impress you... park in front of a white garage door... put on your high beams and adjust the fogs so the focus in just below the center of the high beam...it takes about five minutes and does not require putting your hands down inside the headlights.. this adjustment is done through the front facia.. about 1/4 inch from the foglight itself...and it does not require touching the bulbs.
Old Jul 25, 2004 | 08:13 PM
2KFRC5's Avatar
2KFRC5
I believe he was answering the post directly above his post. How to change the bulb.
Made sense to me.
Old Jul 25, 2004 | 08:34 PM
Evil-Twin's Avatar
Evil-Twin
Made sense to me.
I apologize if I didnt get the gist of his answer... I thought he was answering the original poster... again I apologise... Ive re read the thread and I was out of order...
Old Jul 28, 2004 | 07:48 AM
jperez's Avatar
jperez
6th Gear
Guys thanxs for all the cool info!!
To 99 fog light adjustment!
