Fuel hatch won't open!
Old Jul 23, 2004 | 03:28 PM
KODAK's Avatar
KODAK
Default Fuel hatch won't open!
I pull up to get gas, hit my little button, I hear the click but the door will not open???? I have to pry it open! Anyone else have this issue?
Old Jul 23, 2004 | 03:32 PM
HummelS's Avatar
HummelS
The only time I've had the problem was after installing the Hurst shifter & forgetting to reconnect the switch.
There is a manual release cable in the trunk, behind the carpet over the left wheelwell.
CE2004's Avatar
CE2004
There's a release. On my convertible, it's a silver cable coming out around the waterfall area.
Old Jul 23, 2004 | 04:14 PM
Mike04's Avatar
Mike04
Old Jul 23, 2004 | 04:19 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Me too except there was no click.
Old Jul 23, 2004 | 04:25 PM
mrw173's Avatar
mrw173
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Wd-40
I had the same thing happen to my C5 and Eldo. You need to lube the little pin that holds the latch closed. You heard the click because the solenoid pulled the pin back but not far enough to release the door. Mike
Old Jul 23, 2004 | 05:17 PM
mapman's Avatar
mapman
In your Owner's Manual there is a section on the manual cable release for the fuel door, easier than prying it open.
Old Jul 23, 2004 | 05:31 PM
Never had to use the manual release, but I know it is there.
Old Jul 23, 2004 | 05:43 PM
gutgreen97's Avatar
gutgreen97
Default Gas door
Had the same problem with mine,,,,was not getting any power from the door opener button to the gas door release solenoid. Ran a bypass wire from the door opener button to the gas door release solenoid and it has worked great every since. Be careful prying it open as you could crack the fiberglass gas door.
Bob
Old Jul 23, 2004 | 06:09 PM
hansenisu's Avatar
hansenisu
St. Jude Donor '10
Mine did that to me two days ago, but I pushed the door in a bit and it popped right open and hasn't been a problem since.
Old Jul 23, 2004 | 06:14 PM
LoneStarFRC's Avatar
LoneStarFRC
Crowbar anyone? I guess a dab of lube on the actuator pin from time to time wouldn't hurt.
Old Jul 23, 2004 | 06:31 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
...no prying
pull the manual release...
...check to see if theres spring in the door
...administer a little oil...
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
CROWBAR AND CORVETTE should never be in the same sentence
Old Jul 23, 2004 | 06:35 PM
mrw173's Avatar
mrw173
Default Wd-40
ACTUATOR pin, thats the name of the part, couldn't think of it, thanks. I don't think he really had to pry it open, it was probably right on the edge of opening like the other guy that pushed it in to relieve the presure on the ACTUATOR pin to release it. Little dab L do ya. Mike
Old Jul 23, 2004 | 06:39 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I did the same thing
Old Jul 24, 2004 | 05:11 PM
KODAK's Avatar
KODAK
Thanks for all the help...And no I didn't "pry" it open I just had to encourage it a little!
To Fuel hatch won't open!
