Driver Control Module?
Old Jul 27, 2004 | 08:24 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Default Driver Control Module?
Is there such a thing as a driver control module? If so, what exactly is it supposed to do, and how do you know if yours is bad?
Old Jul 27, 2004 | 08:41 AM
wrustywrench's Avatar
wrustywrench
My neighbors car has two,, one is called W.I.F.E, usually located in the passengers seat, I call it M.I.L.F, usually located in the yard wearing shorts....
Old Jul 27, 2004 | 09:18 AM
Rattler71's Avatar
Rattler71
Old Jul 27, 2004 | 09:52 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
there are door control modules
body control modules
engine control modules
but I have never heard of driver control modules
Old Jul 27, 2004 | 09:53 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
There is a PCM and a BCM Power Control Module and Body Control Module. As far as knowing when they are bad comes down to what's going on with your car and have they been damaged. The BCM is under the passenger's feet. There's a small cover under the floor mat. If this one get wet it can cause all sorts of problems. This happens when the A/C drain backs up and water enters the passenger's side footwell. Hope this helps.
Old Jul 27, 2004 | 02:34 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
That's what's great about this forum. It provides both educational and entertainment value.
As for what type of module, it is the Body Control Module and it was apparently accidentally damaged at the dealer. I thought they were supposed to fix things, not break them. Anyway, it should be fixed but what should I look out for in the event they didn't fix it right?
Thanks.
Old Jul 27, 2004 | 07:18 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
The Driver Control Module is between your ears.
If the car is out of control, then the Driver Control Module is probably bad.
To Driver Control Module?
