Installing backup light switch
Old Jul 28, 2004 | 03:29 PM
00Rocket's Avatar
00Rocket
Default Installing backup light switch
Hey guys got a question? I have tried seaching but came up with nothing but here goes. How hard is it and what do I need to do to change the backup light switch? I am having the problem with no backup lights and I need to get my car inspected ASAP! I checked the bulbs and also the fuses and dont think the problem is with them. Thanks in advance for your help!!
Old Jul 28, 2004 | 03:40 PM
Cajun99's Avatar
Cajun99
I've been fortunate and haven't needed to replace mine. I might be wrong but it is my understanding that the switch is on the passenger side of the tranny somewhere. I haven't had to look for it yet.
Hopefully someone who knows for sure will chime in
TTT
Old Jul 28, 2004 | 08:30 PM
wreakhavoc's Avatar
wreakhavoc
I have the same problem on my '99. Bulbs and fuses are good but lights still don't work.
TTT
Old Jul 28, 2004 | 10:43 PM
HeadsUp's Avatar
HeadsUp
I took a quick picture of my '99 manual. Let me know if this helps.
Old Jul 29, 2004 | 12:23 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Old Jul 29, 2004 | 09:33 AM
Doo's Avatar
Doo
St. Jude Donor '03 & '06
Don't mean to sound like a smart azz but make sure you check your light bulbs. Old car had one out for a long time (I'm Guessing) and never noticed it. When the second one quit I thought something was wrong with the wiring. Spent a whole day chasing it down to inevitably find the two bad bulbs Felt like a huge idiot.
Old Jul 29, 2004 | 09:39 AM
molson's Avatar
molson
It is an easy fix........back up lamp switch just screws in to the passenger side of the trans....if you buy the part you will see where to install..
Old Jul 29, 2004 | 12:58 PM
00Rocket's Avatar
00Rocket
Thanks guys I ordered the switch and will try to put it in tomorrow.
Old Jul 29, 2004 | 01:45 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Thanks from me also. I'm in the same boat. Hopefully you don't really need to disconnect the exhaust to get to it. That sounds like a big PITA.
Old Jul 29, 2004 | 02:20 PM
JC in XTC5's Avatar
JC in XTC5
Just a few pointers. If the lights come on when you hit the FOB (approach lights), the bulbs are fine. Also that circuit is separate from the backup lamp circuit, i.e. different fuse.
If you replace the back lamp switch as per the above (which is a very common problem) make sure you verify the fuse for that circuit. I can't remember the fuse # but it's in the passenger footwell. Usually when the b/up switch goes, it shorts the circuit and blows the fuse.
Old Jul 29, 2004 | 02:48 PM
00Rocket's Avatar
00Rocket
Yes my bulbs work with the key fob and I checked my fuses so I was kind of thinking it was the switch. Thanks guys and Headsup thank for that pic!!
To Installing backup light switch
