A Second Column Lock Recall
Old Jul 29, 2004 | 10:52 AM
Tommyz's Avatar
Tommyz
Default A Second Column Lock Recall
I just called the dealer to find out if my 2000 vette had the column lock recall done and what do I find out??? There is a second recall that went into effect a couple of days ago (July 26th) This recall will replace the harness kit. I hope this will fix what the first one didn't!!
Old Jul 29, 2004 | 12:28 PM
jackj's Avatar
jackj
buy the CLB
Old Jul 29, 2004 | 12:37 PM
markwein1's Avatar
markwein1
Default Listen to the seniors and BUY THE CLB
Good advise!
Don't be stubborn like I was.
Buy it and put it on fast.
If you cannot get someone else to do it.
It takes 40 minutes or less.
GM and the dealers will drive you nuts
if you let them.
Old Jul 29, 2004 | 01:54 PM
get the CLB.
Old Jul 29, 2004 | 02:09 PM
JC in XTC5's Avatar
JC in XTC5
Originally Posted by JDs00PewterCoupe
get the CLB.
Especially if you have an MN6.
Old Jul 29, 2004 | 02:25 PM
GrayC5's Avatar
GrayC5
As I understand it, the second recall replaces the first one. C-5 Tech posted detailed infomation on this here several days ago. See C-5 TECH's reply, 1st one down at this link: Latest Column Lock Recall Details From C5 TECH
Old Jul 29, 2004 | 06:43 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
If you have a 97-2000 A4 the column lock will be disabled...
If you have a 99-00 M6 the PCM will be reprogramend and some enhanced wiring will be installed to the BCM (if you were not involved in the 1st recall)...
If you have a 2001-04 M6 you only get the PCM reprogram...
If you have a 1997-98 M6,you are still out of luck because those will be recalled at a later date...
Old Jul 29, 2004 | 08:13 PM
Garibaldi's Avatar
Garibaldi
get the CLB.
Not to start a p*ssing contest here...
I've not installed a CLB because of info C4C5Specialist has provided in the past that the CLB screws up the BCM.
Anybody have a different take on this?
Old Jul 29, 2004 | 08:15 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I installed my CLB almost 2 years ago & haven't had any problems resulting from it.
Old Jul 29, 2004 | 10:53 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Having delt with column lock issues hundreds of times,I cant confirm that or deny it,but I can confirm that info originated from those at GM
Old Jul 29, 2004 | 10:58 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
get the CLB.
Fixed the problem for me.
column lock
Old Jul 29, 2004 | 11:46 PM
Cajun99's Avatar
Cajun99
I've used the same CLB in two different FRCs over the past several years with not one problem in either car. I have no intention of taking it out.
Old Jul 30, 2004 | 11:43 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
I wasnt aware of that... I registered my car on the mygmlink site and after giving them the VIN they said that there were "no outstanding recalls" on my car.
The last thing I had heard is that the '97-'98's were to be the first ones recalled.
Seems to be a LOT of misinformation about these recalls... thanks for clearing that up
Old Jul 30, 2004 | 06:38 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
1997 A4 was the 1st to be recalled.Notices sent out late April
Old Jul 30, 2004 | 06:41 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
AHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!! !!!
Old Jul 30, 2004 | 08:17 PM
IwantmyC5's Avatar
IwantmyC5
St. Jude Contributor
Just picked up the Z fromthe dealer for the rocking seat and gas filler-neck fix. He said it showed the recall in place as well now. (Of course, they can't do it, because they won't have the programming kit from GM until the end of next week.
Old Jul 30, 2004 | 09:00 PM
schmaltzr's Avatar
schmaltzr
Forgive my ignorance, but what is a CLB? (Club? Column Lock B....?)
To A Second Column Lock Recall
Old Jul 31, 2004 | 08:24 AM
SteveL4446's Avatar
SteveL4446
Column Lock Bypass
Old Jul 31, 2004 | 10:18 AM
BiggieBoy's Avatar
BiggieBoy
w/ NoelsTorchedZ....
Old Jul 31, 2004 | 10:30 AM
Black$heep's Avatar
Black$heep
Well,it is a club. We're all in it.(Column Lock Brothers)
