Valentine 1 question
Old Jul 29, 2004 | 06:03 PM
G_r_i_F_F's Avatar
G_r_i_F_F
Default Valentine 1 question
I just got my Valentine 1 radar locator and have mounted it to the left of the rear view mirror. Since I'm in sunny CA, the V1 is basically unprotected (only the factory tint between it and the sun) from sunlight. The thing gets seriously hot after a couple of hours in the sun!
Should I unmount it and put in the shade when I have to park in the sun?
Thanks!
Old Jul 29, 2004 | 06:14 PM
w28734's Avatar
w28734
I have never had a problem with the heat bothering my v1. I usually take mine off of the windsheild when i park because im more worried about someone running off with it than i am the heat.
IMO its a pretty expensive piece of equipment to leave hanging from the windshield for all to see
Old Jul 29, 2004 | 06:39 PM
JasonFRC's Avatar
JasonFRC
I have my V1 mounted in the same place you do. I was wondering the same thing.
I haven't had any problems with it so far.
The nice part about mounting it up there,is it's not too easy to spot.
Old Jul 29, 2004 | 06:42 PM
G_r_i_F_F's Avatar
G_r_i_F_F
That is a concern for sure ... but like JasonFRC said ... it is up in the tinted area and you can't really see it from the outside, unless you're looking for it.
Old Jul 29, 2004 | 07:38 PM
ACELR8N's Avatar
ACELR8N
I just ordered mine yesterday, and while I was researching detectors, one of the things I came across was that the Valentine case was made from magnesium, making it impervious to heat, and the reason it costs $100 more. Don't remember the source of that info, but it came up in an article from a search engine. Hope it's correct. Think I'll call them, cause I too am concerned about both the theft and the heat.
Old Jul 29, 2004 | 08:55 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Had mine for about 6 years....No Problems and hangs on the window almost every day...all day
Old Jul 29, 2004 | 09:33 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
I've had my V1 for almost 8 years I guess and that thing has baked in some serious Texas sun. I try to remove it from the windshield as much as possible.
Old Jul 29, 2004 | 09:34 PM
chocoholic's Avatar
chocoholic
Is there any particular reason why you don't feel comfortable with the published specs as laid out both on the Valentine web site and in your owner's manual?
Old Jul 29, 2004 | 09:57 PM
NYN8IVE's Avatar
NYN8IVE
Old Jul 29, 2004 | 10:48 PM
Jitters's Avatar
Jitters
Cruising
I have a V1 and it sits in the hot Texas sun everyday. No problem so far.
Old Jul 29, 2004 | 11:28 PM
G_r_i_F_F's Avatar
G_r_i_F_F
Yea ... but just making sure!
Thanks ... I guess it's all good ... no worries
Old Jul 30, 2004 | 12:49 AM
Blue50th_Racer's Avatar
Blue50th_Racer
Default V1
I've two - one on the daily driver, never garaged, six years old, the other in the Vette behind the PASSENGER side of center mirror peeking just below the blue belt with rear antenna peaking out of the right edge of the mirror.
Both units have remotes that sit in the shade, and the daily driver remote died after two years.
After six years, the suction cups on the daily driver have dried out causing a unit drop about once/month... Time to hunt for those spare cups...
While we're on the subject, is everyone else picking up false laser alerts on GM SUV rear LEDs? What a pain at a stop light that can be since the falsing keeps dropping out and back in.
Irritating - I've got to rate this THREE acks...
Old Jul 30, 2004 | 08:52 AM
tT-REXXX's Avatar
tT-REXXX
Default passports
Thanks!
Only passports overheat in the window(per passport cus service " plastic case"
Old Jul 30, 2004 | 09:34 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
V1 sells the suctions cups for almost nothing. I ordered a new lighter plug because I wanted the hidden lights and then had them toss in some new suction cups....
And yes I noticed my V1 going off over a year ago from Trailblazers and now other cars. It is annoying to say the least...
To Valentine 1 question
