I hope ALLKAR or vettethret chime in here. They both run coilovers.
Keep
You rang?
Depending on how low you want to go, give west coast corvette a call and ask for Craig. I have rippie coil overs that WCC ordered. WCC had Bilstein make a 2" shorter shcok body for increased travel. The coil overs are about $2100 and you can request any valving you'd like. I personally wouldnt have a corvette without them. You can adjust the ride hieght at any time and it's very easy. The ride is better to as you eliminate the "cross talk" with the factory leaf set up. Hope that helps.
Sick ride by the way 1hotzo6. I love the red on black.
I do like the LG Motorsports Mounting setup better though.
