Rail Covers
Old Jul 31, 2004 | 08:14 AM
jjk2509's Avatar
jjk2509
Default Rail Covers
I have a 1998 LS1 and I am getting my rail covers painted by Kewl. I need to know if I change my heads out to LS6 heads, will I need different rail covers.
For the price of the painted rail covers, I don't want to mess this up.
Any help would be appreciated.
Old Jul 31, 2004 | 08:17 AM
They will fit right on. I was running a set of Z06 fuel rail covers on my car until I bought a set from Kewl and they both worked just fine.
Old Jul 31, 2004 | 08:27 AM
jjk2509's Avatar
jjk2509
Default Fuel Rail Covers
It is my understanding that 97 and 98 have perimeter bolt heads and the 99 and up have center bolt heads. Therefore, the valve covers are different on a 97, 98 from 2000 and up.
So the real question is, will 98 fuel rail covers fit over center bolt heads and valve covers?
Kewl can order the older (98) or new style. I need to know if the 98 will work on the Z06 heads.
thanks
Old Jul 31, 2004 | 08:30 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
thanks
The rail covers don't attach to the head, they clip onto studs that protrude from the coil packs and they also clip onto the fuel rails.
If you change the heads and go to center bolt valve covers I believe you will also have to change the coil packs, if this is correct then the engine covers may not attach correctly at the bottom but they will still clip onto the fuel rails.
My engine covers have been cut and they only attach at the coil packs so don't necessarily worry that one attachment point will not hold, it's worked fine for me for over a year now
Old Jul 31, 2004 | 08:38 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
But, note that the 98's have two (2) fuel inlet connections on the drivers side. The Z06 has only one. This may be an issue!
Old Jul 31, 2004 | 08:45 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The 1999-04 heads have a center rocker cover bolt pattern.Because of this,the 99-04 coil brackets are different but the coils themselves are all the same 97-2004.The 4 studs that retain the rail cover hold the same coils to the coil bracket,so I dont see why you should have any problem.
Old Jul 31, 2004 | 08:47 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
As long as he does not install a different fuel rail,that wont be an issue
Old Jul 31, 2004 | 11:16 AM
jjk2509's Avatar
jjk2509
Default Rail Covers
Looks like I should be OK
Thanks for the help
To Rail Covers
