Parking brake
Old Aug 2, 2004 | 10:29 PM
Allen N. Schmidt's Avatar
Allen N. Schmidt
Default Parking brake
How does one adjust the parking brake. Mine barely holds on the level.
Old Aug 2, 2004 | 10:31 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
had the same problem...
if your lever goes all the way to the top, and still doesn't hold, you'll need to adjust the drums in the back.
You'll need to pull of the rear wheels, remove the calipers from their brackets, remove the caliper brackets and pull the rear discs out. There is a star adjuster for the drums used for the e-brake. Adjust it out, and put everything back together. Don't forget to use medium loc-tite on the bolts.
I did that, and all I need is 5 clicks on the handle to keep the car from rolling on a steep hill. Hope this helps.
Old Aug 2, 2004 | 10:37 PM
GrayC5's Avatar
GrayC5
Following from C5 Tech Tips: Parking Brake Adjustment
Old Aug 3, 2004 | 12:00 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Parking brake what parking brake. Till I adjusted mine I couldn't use it for anything totally useless. Now that it's adjusted I can't take off with it on. Before I could.
Old Aug 3, 2004 | 12:24 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
I need to adjust mine in the very near future.
To Parking brake
