[Z06] CAGS installation problems
Old Aug 3, 2004 | 07:58 PM
Saba Dane's Avatar
Saba Dane
Default CAGS installation problems
I bought the cags defeat and went to an audio/electronics store to have them install it (I don't have 4 jackstands). The guy told me he could do it, but came back out a few minutes later saying that there is a shroud around the transmission preventing him from doing it. I've researched CAGS installation to death and I don't see any shroud around the tranny. Is this guy full of it and should I just take it to someone with a hydraulic lift and a mechanic?
Old Aug 3, 2004 | 08:12 PM
1hotZ06's Avatar
1hotZ06
St. Jude Donor '05
Yes and yes (if you really can't get under the car yourself). No "shroud" to hide it and one of the easiest of all mods.
Old Aug 3, 2004 | 08:13 PM
C6~Missle's Avatar
C6~Missle
No shroud... just the wire harness that plugs into the socket. remove it and replace with resistor.. 2 minutes.. fool proof... maybe not.
mike
Old Aug 3, 2004 | 09:14 PM
texasredc8's Avatar
texasredc8
Go to Walmart and drop $20 on some Rhino Ramps. Back the car up on the ramp and do the CAGs thing yourself. Its about 10-15 minutes or less. This is a very easy one.
Also, stay clear of any repair shop that is not familiar with the Corvette. There is no shroud, and you don't want somebody poking around your C5 that is clueless. Sounds like he was trying to go inside the tunnel area to locate the relay.
The instructions that came with your CAGs should be fairly easy, or you can browse the Tech Tips section, or just post back and ask an install question.
Old Aug 3, 2004 | 09:25 PM
CRWDDYZ's Avatar
CRWDDYZ
On my 2004 the harness was even labled with white paper tag with bold black letters that read "CAGS". Just like GM new I'd be looking for it. It's rather foolproof. Go to Wal-Mart, by the Rhino Ramps, you will need them for oil changes anyway, which are also very easy.
The harness is located at the driver's side rear of the car,,,the transmission is in the rear in this car. Look for the harness on the driver's side of the transmission. It will be near the top on the drivers side of the transmission. Unplug it and you will see that you can only plug in the Defeat one way. Good luck.
Old Aug 3, 2004 | 09:30 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
I did mine at the dealer durring an oil change! Very easy to do youself. Love your avitar shark and are they on tonight? YEA!!!
Dave
Old Aug 3, 2004 | 10:09 PM
Sho-nuff's Avatar
Sho-nuff
From: When I say who is the masta you gotsta say Shonuff
Go to Jiffy Lube with a six pack and ask them if you can get under the car yourself in their bay area.
Old Aug 3, 2004 | 10:32 PM
TheDVS1's Avatar
TheDVS1
Ahem, I dare say the "shroud" he saw was probably the shield underneath the torque tube. Yes - he was probably looking for the trans up at the engine...
Old Aug 3, 2004 | 11:27 PM
90 droptop's Avatar
90 droptop
Old Aug 4, 2004 | 04:42 PM
SpdKilz's Avatar
SpdKilz
VERY easy:
http://www.spdkilz.com/techtipcags.html
Old Aug 4, 2004 | 05:08 PM
Saba Dane's Avatar
Saba Dane
Thanks for the info! I took it to a mechanic out in the sticks who had a hydraulic lift. He let me under there and I was done in 2-3 minutes. Paid the dude $10 and it worked fine. I'll have to avoid the previous shop I took it to. If I could find the plug, I don't want someone who can't even find the tranny laying a finger on my car.
Old Aug 4, 2004 | 07:18 PM
CRWDDYZ's Avatar
CRWDDYZ
You said brother...should be a Corvette Mantra
Old Aug 4, 2004 | 11:14 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
glad it worked out. 2-3 minutes is all it should take, & that's w/ taking your time!
To CAGS installation problems
