c5's with the same problems
Old Aug 3, 2004 | 09:02 PM
mad99c5's Avatar
mad99c5
Default c5's with the same problems
I only had my 99 coupe since march but I noticed that the problems that I do have, others seems to have the exact same problems.
My rear end seal is leaking and it's at the dealer as I speak.
My outside temp sensor is giving false readings.
My directionals sometimes stop working until I press my hazzard button.
My point is that I see losts of members with the same problems and GM does not have any recalls on any of them. With the rear end seal I
complained and GM will now pay 100% of the repair.
So if enough of us stick together and all complain about all these problems then maybe GM will look into it and maybe have some recalls.
Any input?
Old Aug 3, 2004 | 09:05 PM
jschindler's Avatar
jschindler
I've owned two C5's, and have been on this forum over three years. Two of the problems you point to I've never heard of.
Old Aug 3, 2004 | 09:15 PM
Some problems do seem to be very common. Mine has had a rear differential seal leak three times and has had the rings replaced for oil consumption. You are lucky that GM is repairing your seals - normally if it is out of warranty they will tell you tough luck.
Old Aug 3, 2004 | 11:20 PM
jrose7004's Avatar
jrose7004
I've been lucky and I'am knocking on wood!
Old Aug 3, 2004 | 11:38 PM
C5 4 ME's Avatar
C5 4 ME
Old Aug 3, 2004 | 11:42 PM
vetterlatethannever's Avatar
vetterlatethannever
My temp sensor has gone wacko!! It thinks that it's cruisin in nice 65 degree weather all day!!!
To c5's with the same problems
