4L60E - Myth Busted
Old Aug 4, 2004 | 01:10 AM
LBear's Avatar
LBear
Default 4L60E - Myth Busted
I spoke to a VERY reputable trans expert. He has been rebuilding tranmission for 20+ years.
It is NOT bad to manually hold the 4L60E in a lower gear such as 2nd or 1st or to downshift manually.
The A4 does a really BAD job of deciding what gear to be in. When I want to pass, it does not pick a low enough gear to bring the RPM band to where I need it. It lugs the motor.
Hopefully the 4L65E fixed this problem. Chevy can learn some things from German automatics, such as the paddle shift found in BMW's. They are a blast to drive.
Old Aug 4, 2004 | 01:51 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
that is why tuning works great on an a4 changing the shift points.
I agree there are some cases where you need to force it to gear when you want it there but i would not think acting like you have a manual shift in an a4 from stop light to stop light would be a good thing.
Old Aug 4, 2004 | 02:08 AM
Dirty Howie's Avatar
Dirty Howie
I hope he is right......cause I drive like its a four speed stick somethimes
Old Aug 4, 2004 | 02:31 AM
NSTG8R's Avatar
NSTG8R
phew .. good to know.
cuz man, when i run that thing through the gears from first all the way through sixth, i get worried I might be hurting it.
oh wait ...
Old Aug 4, 2004 | 02:36 AM
Vette346's Avatar
Vette346
Hopefully Chevy can also learn something from the Germans and everyone else about adding more than four gears to its auto. Its a 50k sports car, not a Kia. Its about time they get with the competition and offer a six speed.
Old Aug 4, 2004 | 05:41 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
How do you know if you have the 4L60E or the 4L65E?
Jeff
Old Aug 4, 2004 | 05:51 AM
Nice to know this. I agree that Chevy should get with the program and offer a better automatic that has the manual shift options like BMW, Mercedes, etc.
Old Aug 4, 2004 | 07:45 AM
vstella's Avatar
vstella
So True...Now get a Transgo shift kit and really enjoy the shifts!!
More info here ... www.transgoperformance.com
Old Aug 4, 2004 | 08:31 AM
Miaugi's Avatar
Miaugi
Jeff
As far as Vettes are concerned, the 4L65E is only on the '05's as far as I know, so if you don't have a C6, you don't got one.
Anyone else have more details?
Old Aug 4, 2004 | 08:42 AM
JeffC5's Avatar
JeffC5
One of the reasons I asked is because I just got my Factory Service Manual and under transmission, it's labeled 4L60E/4L65E. So I thought maybe they changed it sometime during the 04 production.
Jeff
Old Aug 4, 2004 | 08:47 AM
C5XTASY's Avatar
C5XTASY
As I recall, the 4L65E was first used in the Corvette beginning in 2003. I read a GM tech article on it saying it was beefed up to be able to handle the Z06 engine (405 hp at the time). Supposedly, GM will be coming out with a 5 or 6 speed automatic in the 2006 models. They are really behind the times in this. Lord, my Explorer has a 5 speed.
Ed
Old Aug 4, 2004 | 08:48 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
So, please, point out to us an automatic transmission with six gears and is the same dimensions or smaller than the 4L65E and is as light or lighter, but can take the same input torque and costs 50% more at most.
I keep asking, but nobody ever can find proof (read: actual specs.)
If "everybody else" has 6-speed automatics that can handle 400 lbs.-ft. of torque, you should have no problem listing them all.
Old Aug 4, 2004 | 09:46 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have done it since day one on all my autos since 1980..............38K on the 00', 80K on the P/U, .etc. w/o issues.
Two things kill these, to much heat........and letting the trans decide on the gear for downshifting to pass or play, bad on the bands/clutch packs.
Keep shifting and have a nice day
Old Aug 4, 2004 | 10:56 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Old Aug 4, 2004 | 01:00 PM
BHP's Avatar
BHP
If you set your shift points properly the trans will perform to your will. Install the Transgo shift kit and adjust parms with LS1-Edit and you will have a "real" tranny.
Old Aug 4, 2004 | 01:05 PM
BHP's Avatar
BHP
Jeff
I cannot personally verify this. There have been many internal changes compared to my '99 and '04. Case still says M30 which is a 4L60E. Supposedly GM went to 5 pinions in '03.
Old Aug 4, 2004 | 05:16 PM
GENERAL ST's Avatar
GENERAL ST
LS1 EDIT ....ON A4......SHIFTS THE WAY IT IS SUPPOSSED TO.
KICKS BUTT!!
To 4L60E - Myth Busted
Old Aug 4, 2004 | 05:34 PM
IMQUIK's Avatar
IMQUIK
KICKS BUTT!!
Old Aug 4, 2004 | 09:08 PM
Vette346's Avatar
Vette346
Well seeing as how nearly every car over $30k has at least five forward gears, and many under $30 as well, Accord, Camry, SUZUKI XL-7 for Gods sake, etc...Now for being able to handle 400 ft-lbs of torque....The entire Audi line has at least 5 speeds, of those RS6(415 lb-ft), A8 W-12(425), Volkswagen has a slightly detuned 6.0 W-12 in the Phaeton, and the new Touraeg V-10 TDI(550). Lexus entire model line has at least 5 speeds and they're launching a new in house performance line to compete with AMG, M Division, Audi RS etc..., Mercedes entire model line has at least 5 speeds and a new 7 speed is set to debut this year, of those C55(376 ft-lbs), E55(516), S55(516), SL600(590), SL65(738), CLK55(376), CLS55(516), BMWs entire line has at least 5 speeds, 6 in all but the 3 series, the 6 speed ZF tranny in the 760(438), Jaguars entire line has at least 5 speeds, 6 in all but the X Type. The S Type R, XKR, XJR(399ft-lbs 6 speeds), Cadillac finally has a 5 speed in the new STS, Nissan has a 5 speed in the Titan/Armada/Infiniti QX56(379ft-lbs, 390 in the Q). Also the Chrysler 300C (390) and the upcoming 300C SRT8(425) along with others costing much more, Bentley, Aston Martin etc....
Old Aug 5, 2004 | 12:20 AM
Dirty Howie
Scissors.....please say "UNCLE" and make him stop
Can I get any of those tranny's to fit under my coupe
