Has anyone had any problems with GM dealers claiming issues with aftermarket intake mods??
None here...and mine is a cut-out in the fan shroud and an obvious departure from stock!
...nor the rear end, nor the shifter, nor the intake change, nor the window valet, nor the CAGS, nor the Superchips programming, nor the TB bypass, nor the bridge change...
...if yours does...come on down to Holler in Winter Park
PS did I mention exhaust, wheels, calipers, brake lines...
